Ambient cycle
Started by lancaIV, December 16, 2006, 08:01:31 PM
Developping a fast relocateable ambiental energy converter :
Hirshbergs airpower plant numbers
https://web.archive.org/web/20110817174850if_/http://www.airpower.co.il/PRODUCTS.htm
compared 40 foot container ( on truck ,ship,helicopter)
https://www.icontainers.com/help/40-foot-container/
3,4¢/KWh price development offer 2004,now 2023 2,5¢/KWh
we can estimate as open source/low-non profit condition +- 1,5¢/KWh electricity generation costs or
15$/MWh power production .
40 sqm required area per 500 KW plant translates to 125 MW/ha or 12,5 KW/sqm  sub-/urban or rural area for ' heat island effect' decrease : sub-/urban cooling
100 KW version required area 20 sqm = 5 KW/sqm
10 KW  version required area   10 sqm = 1 KW/sqm
Challenge,competition : better  same  worser
Turbine,Rotor technique
https://www.aerominetechnologies.com/
5 KWp nominal ,3mx3m generator dimension  ~ 0,55 KWp/sqm
A single Aeromine unit provides the same amount of power as up to 16 solar panels.
https://www.google.com/search?q=aeromine+patent&ie=utf-8&oe=utf-8&client=firefox-b-m
Data-check in german
Clearly,by the second - for 24/365,25 work -
Desla Ortosh
Today, wind turbines operate at 80% capacity in the wind - from 9 m / s. Solar power plants are working day.
Adding my device in the design of wind turbines and solar power - will allow wind generators operate at 80% of its capacity, with a wind speed of 0.8 m / s, and solar power plants - 24 hours a day.
Steinke Windsail
Michael Waters Windwheel
Third party and direct comparison test
There have been three separate third party tests, including computer flow analysis. My own direct comparative tests against a conventional high performance wind turbine in a broad range of conditions confirm theory. We ran direct comparisons in real world conditions for days because 3rd party results seemed too high. An aerodynamicist study over several months of tests found a maximum of 122 times more efficient at 14 mph.
Jasim Al-azzawi
Generator improvement technique
Aeromine +Arestov-coil winding generator        + Desla
Steinke + Arestov- coil winding                            + Desla
Waters + Arestov                                                    + Desla
Al azzawi + Arestov                                                + Desla
Special case,only modelling 1:100  :
coupled with
Aeromine,Steinke,Waters,Al azzawi mills
with improved torque and EMF magnet array generator
and
Arestov double winding
and
David Yurth generator coil coating
and
Desla
Hourly min. wind speed  ? m/s need for 80%,90% nominal capacity and conversion ?
Natural wind force substituting by artificial ventilation
Surplus electricity storage :
from older idea
https://patents.google.com/patent/DE19734733A1/en
to
similar concept :
https://m.youtube.com/watch?v=R9XMWHFzPs8
Thermal batteries can become cheap :
https://www.sciencedirect.com/science/article/pii/S0306261923001174
1/10 from lead batteries price per KWh
Torque amplifier !? Endless Free Energy ?
https://itwire.com/science-news/energy/fuel-free-%e2%80%98power-generation%e2%80%99-business-seeks-partners-to-roll-out-across-the-world-a-fusion-energy-beater.html
The secret not in Helmholtz FE,not in Gibbs FE,but : Helmholtz in Gibbs FE to find ! Mechanics
Permanent magnets ' have not energy' ,then what ?
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=22&ND=3&adjacent=true&locale=en_EP&FT=D&date=19900516&CC=EP&NR=0367760A1&KC=A1#
EP/DE proved AND granted technical standart patent ! Now,2023,free source !
Victor Arestov generator improvement by ccw/cw double winding
the rotating wind-/water rotor-shaft coupled to
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=14&ND=3&adjacent=true&locale=en_EP&FT=D&date=20130814&CC=DE&NR=102012002418A1&KC=A1#
coupling a second multipole generator ?
Like this
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=16&ND=3&adjacent=true&locale=en_EP&FT=D&date=19890209&CC=DE&NR=3804440A1&KC=A1#
Instead water-/wind-rotor electromagnetic device rotor-shaft ?
The GGOE gearbox concept https://www.ggoe.org/
will let also people think aboutMichel Porquer his mecano-electrical  concept
Li Yng Tyan transmission concept
Gigadron  https://m.youtube.com/@mikinvent/videos
functionality,force transmission process !
https://jbpowersystems.weebly.com/index.html
https://www.google.com/patents/US8541894
EPS Electric Engineering Testing Company did the testing for the event:
1. We have a 3 phase generator that has 42 coils in it. (the more coils reduced the number of rotations it needs to produce energy)
2. We have 18/1 gearbox. (this is called a torque multiplier)
3. We have a toque arm that is 10 feet long.
4. The Force is produced by man pushing.
5. We have a fish scale to pull the torque bar to see what force the man would have to push. (10-25)lbs
6. The Man will turn the torque 5 complete rotations.
7. Each rotation turns the gearbox, which turns the generator 5 x 18=90 rpm
8. Each rotation the man travels 10 ft x 3.14 (360 degrees) = 31.4 feet x 5 rpm = 157 ft travel per minute x 25 lbs(per ft) =3925 ft lbs minute  x .74 (watt sec)=2904 watts per minute
9. The engineer meter read 30 volts x 20 amps = 600 watts per phase x 1.732 = 1020 watts per minute.
10. 1020 watts is true power watts out of 1800 watts produced,  also 1020 watts per second  x 0.74(watt Second) = 754.8 ft-lb's sec x 60 sec(minute) =4 5,288 ft lbs per minute x 0.74 = 33513 ft-lb's per minute and the energy used to produce this is 3925 ft-lb's minute. Take 33513 ft-lb's minute divided by 3925 = 8.5 power. It  produce than used
https://patents.google.com/patent/DE4304132A1/de
The search/find from No-straight-line ' Ohms law'/'Siemens law' kinetical/mecanical exception
https://en.universaldenker.org/lessons/287
A conductor fulfills Ohm's law only if the voltage-current graph results in a straight line.
Torkel line experiments ! Rotating around this line !
Cloxxki
Watts per minute?? Back to school!!!
Quote from: Cloxxki on August 09, 2023, 05:42:16 PM
People in R.I.P. estate need to go back to school ?Even the death gives not peace ! ;D
;) OC
p.s.: but the 8,5 ... You do not critizise ?
        Wrong or right ?
        https://jbpowersystems.weebly.com/the-energy-multiplier-system.html
