Ambient cycle
Started by lancaIV, December 16, 2006, 08:01:31 PM
Wilhelm Haeberle ,work performance claim 5x+
Edvid Linevich,work performance claim 16x
Oskar Becker,work performance claim 100x+
coupling :
Haeberle + Linevich + Becker ~ work input/output process C.O.P.: 5x16x100 = C.O.P. 8000x ;
ir-/rational !?
A.concept references :
1.   Air/Air heat pumps are known with C.O.P. 2-4 ( ' inverter technology') ,Air/Water with C.O.P.5-10
2. Linevich device,a cw/ccw centrifugal/centipetal forces transmission  in its application description also mentioned as heat pump drive
[ 0024 ] ! here :
https://worldwide.espacenet.com/publicationDetails/description?CC=DE&NR=102012002418A1&KC=A1&FT=D&ND=3&date=20130814&DB=EPODOC&locale=en_EP#
3.Becker synergetic motor such high work performance claiming by each ,compared household motors large diameter,motor poles,in large numbers, as independent electromagnetic circuit
1 metre wheel diameter rotor x 10 electro-magnetic pole couples = factor 100
heat pump + Linevich coupled,by claim C.O.P. 80x
How much more architectural ( i-/mobile house construction ) freedom the society would get ?
Linevich + Becker coupled,claimed C.O.P. 1600x
By Linevich 1:20  up to 1:100 step down transmission ratio,electric fixed/variable RPM need ?
How much less green-house gas emission the world population will in nearer future emit,related energy/power generation !?
Not enough ' surrealism' ?!
Linevich + Becker + Zielinski superconductive coil transformer ,claimed C.O.P. in conjunction ?
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=15&ND=3&adjacent=true&locale=en_EP&FT=D&date=19881020&CC=WO&NR=8808220A1&KC=A1#
Accordingly, a generated power of 990 kW can be drawn from the terminals 89 for a power supplied to the connecting terminals 88 of 1 . 1 kW, and this corresponds to a power gain of approximately a factor of 1000.
16            x 100         x 1000 = coupled CO.P. 1 600 000
An apartment,80 sqm floor area ,older construction,in lowest temperature 0°Celsius climate zone needs 4000 Watt-peak heat for in-room average 20°C temperature .
4000/C.O.P. 5 = 800 ~ newest 20 Wp/sqm heating primary energy maximum ' building standart'
4000/(C.O.P. 5 x 16 ) = 50 ~ 1 Wp/sqm heating primary energy consumption,1/10 from 'Passive House'-10 Wp/sqm-Standart demand
Future : fast relocateable ,fast inflatable, bubble-domes ,net zero energy housing,ambient heating/cooling related
In colder than 0°C area,instead heat pump,alternatively
Imris induction water/liquid heater,C.O.P. 10+ claim
Beier graphene heater,C.O.P. 10 claim
Nearly zero human worker house construction standart :
Apis Core,Icon,WASP,Contour Crafting/Winsun,Norman Foster Foundation/Holcim,woodframe house,Ecobeam,F.A.S.org housing program,Elementals 'social house' competition,Domes International,Interbloco,Polycare,N55.dk   :
average international new sqm house construction value : ≤ 200 IMF $,with net zero HVAC ≤ 250 IMF $
By CIAM 1929 conference : 4 x 9 sqm each individual  + 30,5 sqm common social area = 66,5 sqm 4-capita family house
~ 4x great trailer area, nearly 2x Ikea 35 sqm 'house' : physically enough living space for 4 humans
+- 17 000 IMF( Intern.Monetary Fund) $ relocateable house ,  66,5 sqm ,with net zero HVAC
64 sqm is the south-african A-frame Power Profile Building living area offer,2006 their comercial price ≤ 10 000 € or +- 150 €/sqm floor area
FPB,foldable portable building,60 sqm expanded floor area,by Kalinowski,' popular mechanics'-article in the end 80',by mass production 15 000 US$ ,~ 250 US $/sqm living area
Social law& order books livings costs ( consumer basket index ) relationship for residents/migrants :
https://www.n-tv.de/politik/Diese-Sozialleistungen-bekommen-Migranten-in-Europa-article24441742.html
FE,thermodynamic potential,-devices and FP-fall,Free Price economy
Actually energetic modernization projects,well organized and worked out,gives up to 80% energetic consume savings ,financial -before/after- between 10-30% savings  ,in Germany !
https://www.bausubstanz.de/aktuelles/Rebound-Effekt-Wenn-nach-der-energetischen-Sanierung-die-Heizkosten-zu-wenig-sinken/
A before: C.O.P 1= 100%  consume household
bringing to C.O.P. 10 ( also as PE/EE ratio )= 10% heating/cooling energetic performance as first target,
C.O.P. 100-1000 and more :  later STANDART !
Too fast in progress ?
Some of us work faster,faster than the average human  ::) ;) ,as we get :
' You have requested resources from our servers too rapidly. We have determined that you might be a robot.' ;D
A 20 sqm ' living box ', by  PUR- or EPS- foam formed :
Dr.Helmut Reichelt objects resonative heater/cooler : up to 40 W per 20 sqm
990 KW the Zielinski transformer output
40 /990 000 = nearly 2500x less material input - micronizing- the driver for the Reichelt-thermotexx heated ' living box'
per day maximum heater electric consume : 24 hours x 40 W  = 960 Wh / nearly 1000 Zielinski C.O.P.
                                              1 Wh per day /20 sqm living area/space power storage need
40 W resonator electric consume :
human physiologic temperature versus physical measured temperature
Subjective heating : 100 W per 20 sqm ' empty space'
Objective heating : 12 W per object
30/70 ratio : (100 x 0,3) + ( 12 x 0,7) = 38,4 ,this in Watt = near Reichelts ' 40 W'
From ' Planet Earth ambient cycle ' to its ' Moon/Luna ambient cycle ' :
best locality for installation of CONVENTIONAL superconductive coil generator/transformer !
From Moon to Earth generated power by microwave emitter !
25°Kelvin atmosphere as lowest ! Low temperature superconductor best case !
https://www.google.com/url?q=https://lunar.gsfc.nasa.gov/images/lithos/LROlitho7temperaturevariation27May2014.pdf&sa=U&ved=2ahUKEwiOg7zlhN-BAxV5T6QEHWhQDBIQFnoECAQQAw&usg=AOvVaw2Wyq19TGCtoPzEPoYA4W-e
Lunar migrants colony plan :
https://t3n.de/news/nasa-2040-haeuser-mond-icon-1580167/
