Magnetic wheel by steel shielding
Started by vineet_kiran, February 02, 2019, 08:15:48 AM
nix85
Practically everything you wrote is wrong, no need to repeat myself.
Floor
Cause and effect, action and reaction, relativity, and other scientific precepts
are first found / originate as principles within  metaphysics.
Described in metaphysical terms.  The universe manifests in planes or stages.
From "higher" to "lower".  And yes, at least in the lower planes, speed or frequency
has a lot to do with that order.
Differing expressions of those principles arise from differing cultural back grounds,
but the fundamentals of those principles remain essentially the same.
Before time could exist, (as if the word "before" has any meaning except within a
context of time)....
out of unity came a trinity.
              or
From one came three, and from three came the many.
Those three are called... quantity, difference and relationship
(in older language numbers, letters, and sound or vibration).
One in essence but three in aspect.
From three came the "many".
The "seven" planes of manifestation.
Floor
But this topic is about "free energy" from magnets, not metaphysics.
Are there methods by which to effectivly shield magnets,
without expending just as much energy to intall and remove the shielding,
as one can then receive from the magnet repulsion and or attraction ?
si.
nix85
Gravity is a dipole, bands of attraction and repulsion alternate around the sun and planets creating alternating gravitational valleys where we find planets and asteroids and hills where we find nothing. Like everything in nature orbits follow the progression of Phi.
Spirit is beyond illusion of mind (time space). Spirit creates mind as a negative contrast to appreciate the original bliss.
How to understand the bliss which is beyond time and polarity. You cannot understand it mentally but you can sense it cause it is you and you are forever, indestructible.
How would you create something from literally nothing. Obviously you must simultaneously polarize the "nothing", that is, your consciousness. Brahma (creator), Vishnu (maintainer) and Shiva (destroyer) or +1,0 and -1.
This polarization of nothing allows for creation of time-space.
First is imagined infinite vibration. A proto-mind filled with vibrations of infinite frequency, infinite amplitude.
This infinite vibration is bound by vibrations of limited frequency and amplitude creating interference patterns along 6 axis of time creating the illusion of 3D space.
Creation is divided into 7 great cosmic planes, it has a nesting nature. Scale is so mind boggling it is almost ridiculous but i'll repeat it as described by Bentov.
Our universe +48 similar universes like beads on 7 level spiral make one "cell".
15 such cells form a double tetrahedron structure 1 on top than 3 then 7 then again 3 and again 1 giving a fine-structure constant 137.
Thousands of such structures create one even bigger cell and unknown number of such cells make the FIRST OF 7 GREAT COSMIC PLANES.
You can see the immensity of just first plane, next 6 higher ones are not described by Bentov.
What is important is that at the top of the 7th plane sits in a meditative posture a non responding replica of you. As you merge with your self, bang happens and you realize you have always been the non-manifested consciousness.
In the illusion of physical and metaphysical creation scaling follows the ratio of 7x7 that is 49.
So if you go one level above this one you will find
Speed of light, density of matter and rate of time flow are x49.
This ratio is encoded in the Bible, of course, totally not understood.
It is said 7 (or 7000) is number of God.
7 days (tones) of creation.
Image below is screenshot from Solar System by theosophist Arthur Powell. It shows how smallest particle on our plane (something like Planck constant) contains near 14 billion particles of the first plane and this refers just to first GREAT COSMIC PLANE.
