Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
color
Note that,
If you report a spy in Korea, you have a reward of hundreds of thousands of dollars.
Usually it is a North Korean spy.
You can not open a blog under your own name.
The name and user are another illegal blog.
My friends manage it.
https://ncache.ilbe.com/files/attach/new/20190217/377678/23485223/11021467988/0b0999d9301bb81ca15320533afec965.gif
It is unique culture of Korea.
color
Free generator is all of mankind.
Some people are too common to monopolize.
I am bored and I am looking for a place to have fun on the internet.
If life is bored, it is not pleasant.
https://ncache.ilbe.com/files/attach/new/20190216/377678/10766642182/11020749754/d37f7cb3acb25118ef8a832f01b43d43.gif
color
Existing circuits are error free.
Ruslan said:
Не путайте вращение поля и создание реактора с обычным ВЧ трансформатором.
Conventional transformers do not create special resonances.
Conventional transformers do not amplify the charge pulled from the ground by the kacher.
We have to make a new transformer.
This is the part that needs to wake up the brain.
If Minwell generating 12V / 10A produces 209V / 7A through the generator, the Tesla kacher has a 1/10 role.
The remaining 9/10 is made by a yoke transformer.
What Tesla kacher has done over the past 100 years is almost certain and nothing special.
What to expect from Tesla kacher is nothing more than a mirage made by the Tesla name.
Kapanadze and Ruslan hid the real free generator principle by mentioning the Tesla name.
Make a new yoke transformer!
This is the only answer!
color
If you want to discuss kapanadze generators, start over here again.
[1482] 1483 1484 1485 1486 1487 ... 1516
https://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg474393/#msg474393
cheappower2012:
February 17, 2016, 03:55:25 AM ≫
People don't get just how devious Tariel is,he says things untrue because he knows that people will focus on them,there red herrings.I can't get a certain this or that,people grab and run with it.Tariel and SM inventor of the tpu think the same,fake out people looking to replicate there devices.
The kapanadze device has nothing to do with Tesla,he says it does so people will focus on Tesla.Hoppy's approach is  correct, if a device is a possible fake ,can I show it could be,you don't want to spend time investigating a fraud believing its real thats madness.However  you have to be very careful that you don't declare a device as fake, but it really maybe real.The picture very much sums up how complicated figuring out Tariels device is,without a core concept.From a logical stand point the blue coil is simply that a long coil wound in different directions,an air core,a current must flow between the ground and the end of the coil,to a load(heater).At least 9 amps must flow to light the heater,the coil has very little inductance,winding it in different directions  causes the effective inductance to be less than a simply wound coil.The other end of the coil connects to the 3 phase transformer with a resistance of 78 ohms,from a logical standpoint it must therefor be a fake,since its impossible that it could work.To make Hoppys theory correct you would have a small wire shorting the transformer connection where the blue wire connects.A wire goes to this connection hidden,in back of the transformer this wire then connects to the bundle of wires,this then goes to the back connecting to the long out side cable,and the mysteries
solved.You can see that this is a very hard problem,this is why the giant brains,more or less gave up.Keep in mine I believe its real and uses principles very different from how I was taught in college very hard to
figured out, both the tpu ,not all are real,and kapanadze's devices operate in similar ways.
Zeitmaschine:
February 17, 2016, 01:30:35 PM ≫
This is also true for the drawing below (Patent US6104107).
https://patents.google.com/patent/US6104107
The secondary L2 of the high voltage transformer (Alternating Density Generator) does not form a closed electric circuit, hence it can't generate a magnetic field, hence there should be no counter EMF in that transformer. Nevertheless an oscilloscope connected to coil L3 measures clearly some sinusoidal voltage, meaning, the coil L4 must generate a magnetic field somehow. Impossible?
Not according to my experiments. Although a capacitor in parallel to L4 is necessary in order to work at the low frequency of 50 Hz (not 1 KHz to some hundred KHz as mentioned in the patent). The capacitor and L4 must form a resonant LC circuit at the frequency of the AC source (this corresponds to the 3-phase parallel LC circuit in Stepanov's carpentry setup).
Here connection Bx6 would be the point where Kapanadze put the clamp meter between in order to measure the (impossible) ground current. So far my meter shows nothing, but then, where is the energy coming from that generates the magnetic field through L4 (also open)? Obviously not from the AC source because the open L2 can't generate any counter EMF.
What's missing here? Is it perhaps the simple frequency doubler circuit like seen in the Stepanov's cardboard box setup in order to get a special resonance?
Just something to think about ...
https://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg474485/#msg474485
Zeitmaschine:
February 17, 2016, 05:50:04 PM »
What is electric (ground) current? In order to measure an electric (ground) current by means of a clamp meter the electrons in the wire must generate a magnetic field around that wire. Otherwise the meter will show nothing.
So how to accomplish this without a closed electric circuit? This is the main question here!
In Stepanov case (image to the right) the only way to fake that ground current (here the battery is the conductive body) would be to tamper with the inverter - namely creating a short between the 12-V-in and the 220-V-out side within the inverter in order to have a closed circuit.
But then the question comes up: Why should Stepanov showing a fake ground current without good cause? Why unnecessarily faking a ground current? He could claim more energy out than in easily without showing that ground current.
This question stays unanswered.
By the way: What things could happen if we connect two different coils of a 3-phase transformer to two different frequencies, like 50 Hz and 100 Hz, phase-locked to each other? Anyone tried? :)
color
https://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg475235/#msg475235
Any circuit schematic or a working one? The latter could be more difficult to obtain, I think. :P
A good start point would be to apply the »rule out« method. Any component ruled out can't be any longer a wrong component.
Inspecting the aquarium II device in detail, what do we see? There are few wires coming out of the hidden part. I would call it »neatly arranged«. Six wires are going to two switches and to the connector for the startup battery. We do not care about that wires. Two wires are going to the spark plugs. We do not care about them either, because that sparking is just for the amusement of the audience.
We do care about six wires going to the 3-phase transformer and one coaxial cable going to a hollow plastic tube. The coils on that plastic tube do - you guessed it - NOTHING! No chance that this blue and that enameled wire could ever amplify any electric current. This is totally nonsense.
The output consists of two blue wires. One should be connected to ground, the braid of the coaxial cable is (most likely) also ground. So, what's left? We have to connect the second blue output wire to the center core of the coax, since the coils of the 3-phase transformer can't withstand 9 amps (2000 watts load divided by 220 volts), unless ...
The choices here are either the high current comes out of the device's hidden part via the coaxial cable, or the 3-phase transformer generates that current somehow right in front of the audience (which is amused by the sparking).
Would we are better off if we could see the hidden components? If we could see one more (3-phase) transformer or a capacitor it would change nothing, because we would not know what currents are circulating in the windings.
Therefore more theory is needed. Below there is an illuminating newspaper clipping, »Static on Moving Object Forms Magnetic Field«. So as we do have static in form of high voltage (pulses) in an open transformer circuit, we could form a magnetic field from static by moving that static. How to move that static without moving the transformer? Apply a magnetic field to that static field so the static forms an additional magnetic field which should result in an exceptional strong magnetic field. That magnetic field then interacts with the crystal radio LC circuit (hidden part of the aquarium II device, in plain view on the floor of Stepanov's workshop).
A crystal radio works because the antenna is always statically charged with a bit of voltage (from the environment), then this static is subject to the very weak magnetic field of the radio waves coming from a remote radio station. Now we connect the antenna to something that produces a high level of static AND a high level of a magnetic field. What should happen?
If nothing happens, then something has to be wrong. Hence, the part list:
1) One choke (single- or 3-phase)
2) One 3-phase transformer (in special arrangement)
3) One diode bridge (for the frequency doubler)
4) One power resistor (runs hot)
5) Some capacitors to get the resonance
If we need more parts, the setup can't be right.
Some similarities to the yoke device are by sheer chance, I suppose. Pulsed high voltage is mixed with a magnetic field powering a LC circuit.
Interesting coincidence by the way: Remember, Kapanadze's green 3-phase transformer is connected 5/7 5/7 5/7 to input, 3/4 3/4 3/4 is connected in parallel without load and thus to nothing, 1/2 (88 Ohms) 1/2 (80 Ohms) is connected in parallel (through a fancy coil) without load and thus to nothing. 1/2 (78 Ohms) is connected to a blue wire (1) and open (2). Hence, there are three inputs, but only one static (open) high voltage output.
Does this remind us of something? What about the second Stepanov transformer? Clearly two coils are open so they do nothing like 1/2 1/2. That Stepanov transformer has no pins 3/4 3/4 3/4, so it's not applicable. But then the right hand coil of that Stepanov transformer is connected to some wires - exactly like Kapanadze's little green transformer. Strange thing, isn't it?
I almost forgot: ... unless that transformer generates a strong magnetic field that attracts (sucks) electrons directly into the resonant load circuit, not into the flimsy transformer itself.
Nothing to comment about the strange similarities between the Kapanadze aquarium II transformer and the Stepanov transformer?
Now I have to look for a suitable 3-phase transformer to experiment with in order to post a suitable resonant circuit. In the meantime the search for hidden wires goes on.
Where do you think is the hidden 'x' wire in case of aquarium I presentation (see below)? The ground cable (same as green box cable?) goes straight to the faucet (no bearded man with long sleeves between) and none of the bystanders complains about the possibility of a hidden wire somewhere.
Anyway I think we have already seen all components but we are to stupid to connect the dots.
All we need is a magic transformer, maybe we can find one.
https://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg475264/#msg475264
https://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg312806/#msg312806
cosmoLV:
February 14, 2012, 07:18:35 PM »
Quote from: John M on February 14, 2012, 03:03:21 PM
Cosmos - I will looking forward to your input as well as T1000 and others. Don't worry about this technology being used by Terrorists, etc. This is really nothing compared to the hidden technology the US and other countries have. We can't be afraid to move ahead.
John
I Have friends in military and in Government - and i can say to you that no US army and any other have such technology to stop this!
What they have? Microwave weapons, Ultrasound and e.t.c. this is nothing...
They don't have such magnetic field technology and never had.
yes they know about this technology in theory, that way they afraid from this more than you imagine - in every country is US army base stations, even in Latvia.
Before you talk something bring facts and not illusions and dreams. Be real!
P.S.
Yes they want such a technology, that way there is free speech, because, this maybe a secret info, but all social media, youtube and free energy forums all about - to bring involved us to help in not straight way. More people involved to this, more possibilities to crack this technology up!
if schematics will be released - they very fast get this! and not for security, but for control humanity. (yes for security too, but the main reason is for control) this is all about, to control money and peoples.
This technology need to be first in our hands widely than army or government.
How to do this? by letting crack this up individually by little help if you once get this magnetic field - you will be amazed and I'm sure that you will not post schematics! there are out many in Russian forums who already have it done and they already leave forums - just i stay as curator.
https://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg475288/#msg475288
Zeitmaschine:
February 23, 2016, 04:25:23 PM »
cosmoLV: » ... if you once get this magnetic field - you will be amazed and I'm sure that you will not post schematics!«
The major problem with this thread (and also others) is that almost no one looks back and reads what is written 10 or more pages ago, because he thinks, if the latest page does not provide complete information how to construct a free energy device, then the previous pages will have even less information on it. Therefore the thread goes continuously in circles.
Here back in 2011 Guntis explains the basic principle in one sentence.
Quote:
Originally Posted by scratchrobot  View Post
I know you will release soon, you are good person, i know
You say we need power from outside, maybe you mean attract ions from air and conducting them to ground?
For coil to create ozone you use wire with special insulation?
The metal you use in coil is aluminum foil?
ions are attracted by ionisation.
this HV field are magnetised with vibrations and we get wery poverfull magnetic field "and this field are this outside power"
i use aluminum alloy
http://www.energeticforum.com/138632-post126.html
The theory: A transformer has to have at least two primary coils and one secondary coil. The first primary coil generates high voltage pulses in the secondary coil, whereas the second primary coil generates an additional magnetic field. One primary coil works at twice the frequency of the other. Therefore neither a flyback from a TV nor a transformer from a microwave oven is suitable for that.
Now I'm anxious when the time of amazement will come to me.
It is refreshing to read the old article ..... Like a faint fragrance ....
I am curious about the person who writes such scams.
