Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
0 Members and 18 Guests are viewing this topic.
color
My dad did a lot of experiments that went against the laws of electricity.
One of them.
This is an experiment drawing my dad did a few years ago.
referenced Akura 0083 and Ruslan's hand-drawn schematic.
My dad ordered and tested representative transistors and MOSFETs used in Russian and English-speaking electrical and electronic cafes.
just to experiment with different kinds of transistors.
I have a 494-4421 push-pull circuit with a 30W load light, the max voltage is 120VDC and I couldn't get it to rise any further.
According to my dad, with the diagram below, this is the maximum and the limit.
Experiments were conducted with various transistors and MOSFETs, but the performance was almost the same.
The 2sc5200 and 2sk1162 are transistors that Ruslan used in his generator, but my dad broke a lot during the experiment, so it may not be a suitable part for the generator.
color
Another experiment.
The basic structure is based on LC resonance.
However, it is not a typical LC resonance. Daddy was looking for a little change.
The voltage output from the grenade coil is about 180~190VDC (30W light) with an analog tester.
Over 200 VDC as a digital tester instrument.
Detecting does not work even if the maximum value is adjusted to 500V.
Perhaps Rusland would have been similar if it had been measured with an analog tester device (203 VDC).
The reason why my dad gave up the push-pull circuit of the 494-2110(2113) combination in the past is because he knew through experiments that the 494-4420 combination would output a high voltage.
The reason my dad did an amperage increase experiment with a lot of capacitors was to find a solution because the amount of current of KW was not output.
However, he spent a lot of time, but the experiment was unsuccessful.
Even when air-conditioning with earth-ground, more than 180~190VDC (30W light) is not output.
A combination of 494-4421 push-pull circuit and 2SC5200 and many other transistors were used.
There is this sentence in the record of Dad's experiment on that date.
The circuit diagram of the Ruslan generator has a structure that does not exceed 200W.
You have to find another way.
Ruslan Kulabuhov energy device open internals 1 of 2
https://www.youtube.com/watch?v=t2sciX4022w
And my dad said he saw a strange question in the video above.
color
30W/225VDC output (old data).
One of a few experiments with over 200VDC.
I used a regular 220V/24V/6.3A PSU, not battery power.
color
No added parts.
This is the voltage output by reconstructing the existing part in the Ruslan schematic.
If the Kacher doesn't work, there's no voltage on the diode bridge either.
There is no frequency change either.
1.445Mhz.
Occurs when the 41m grenade main coil is electrically vacuumed.
Neither AC nor DC.
The 38 m grenade main coil has no electricity.
But electricity is generated.
Reference was made to the yoke-transformer and grenade coil structures in the schematic below.
color
Почему?
https://www.youtube.com/watch?v=QU7q80s2IAQ
Snubber capacitors are of good quality, but regular 0.47uF/2000 capacitors also work well.
and,
My dad hasn't been experimenting with generators since years.
Эффект для генератора или почти БТГ.
https://www.youtube.com/watch?v=-tE4coqxwY4
Where my dad got the excess electricity was the unexpected result of a random experiment.
It's not a capacitor, it's just an electrical imbalance.
Lightning principle.
The ammeter is also dead because of the kacher high voltage.
Analog ammeters with a capacity of 15 amps will be disabled over capacity.
Energy one vire 230 v Milutin Miletic SERBIAN 2 / 3
https://www.youtube.com/watch?v=8G3kfcIl09o
Connecting the electrically short circuited wiring structures together is achieved by kacher's high voltage and diode bridges.
I see it as single wire technology in a broad sense, but my dad didn't learn electricity systematically, so I'm not sure if the concept is right.
My dad is still learning electrical systems in uncharted territory outside the map.
