Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
color
vasik041
Was the picture above the generator you made?
One way to increase your chances of free-generator success is to experience seven thousand failures like Edison did.
You have a higher chance of success by experiencing this failure.
The English way of thinking is convenient and practical.
African tribes who have come to play for a while and then have to go back will not understand.
https://www.youtube.com/watch?v=n6Quo7lUUCQ
color
не работает эта бойда, десятки тыс людей делали, это фейк
https://realstrannik.com/forum/btg-tarielya-kapanadze/1389-btg-kapanadze-teoriya-i-praktika-2?start=6620#168281
Hundreds of millions of people tried it, but it didn't work.
So the generator is fake????
Cro-Magnon man Hundreds of millions of people tested it and it didn't work.
Even if Edison or Tesla were reborn, they wouldn't be able to build the generators of Kapanadze/Akura/Ruslan.
Generators with this structure cannot be made except by those who have succeeded in generating generators such as Capanaze/Akura/Ruslan/others.
There are only electricians who are looking for the result of their accidental success in conventional electric common sense.
More cosmos came and died than cosmic stars.
Russians are looking for extraterrestrials, preferring the simplicity of thinking that only humans existed in the process of creation and destruction of countless universes.
This is the member's self-acknowledgement of logical errors and contradictions.
Seven thousand experiments are meaningless.
Only the possibility of success is valid.
In another experiment of my dad,
Ⓐ and Ⓑ diode bridge type generator works.
The premise is to understand and install the structure in which the generator works.
Someone must have painted it without thinking, but this is not a thoughtless drawing.
who drew it?
color
I don't believe in voodoo magic.
99% of human beliefs wish for useless things.
Human belief is the source of "self-hypnosis".
This area of ​​belief is not about right or wrong, it is about wanting what you want.
Now faith is the assurance of things hoped for, the conviction of things not seen.
Heaven and Hell are just one aspect of faith.
Eastern philosophy and Buddhism define this as human desire.
color
yes, my feeling is that with 24V there should be much more voltage on the secondary top / antenna.
Presently i can pull a 0.2mm spark with a screwdriver which should be mm's i think, even with this low duty cycle the kacher is running on.
https://www.overunityresearch.com/index.php?PHPSESSID=7v83u0ao3qjdu3ehak895bp3v6&topic=3926.msg93808#msg93808
Well, this is Tesla coil, not kacher, you will need tune everything yourself :)
I would suggest you disconnect antenna coil and measure Tesla's secondary coils resonance with signal generator.
Then measure antenna coil capacitance, just for reference.
Then you can try use Gorchilin's calculator to calculate resonance and you will need adjust it to match gradient coil resonance.
Verpies rigth about geometry, center of inductor should be close to first turn of secondary (place where current node will be).
https://www.overunityresearch.com/index.php?PHPSESSID=7v83u0ao3qjdu3ehak895bp3v6&topic=3926.msg93815#msg93815
Генератор Свободной Энергии (дополнение и демонстрация)
https://www.youtube.com/watch?v=o1vZ_Vg_y3E&t=500s
Ruslan touches the kacher secondary coil ferrite-antenna with a screwdriver, but only sees very small sparks.
This generator is a kacher construction, not a tesla.
Even using a 12V 10A PSU produces a very long Фитонит in the kacher secondary coil.
The 2KW light turned on and the Фитонит turned into a small spark.
The kacher can only be grounded on the negative side of the structure.
What understanding does a very long Фитонит need to translate to a 2KW light?
Самозапит
https://www.youtube.com/watch?v=gFQvMjj6DD4
The video above is a Tesla-structured generator.
A yoke-transformer with IR2110 can generate high voltage without using a tesla.
My dad has a lot of experience making about 46VAC for a 2KW light with a 24V 6.3A PSU.
Equivalent to 50 40W lights.
The member in the video above did not run the free-generator, only the yoke-transformer and the Tesla.
This means that it is not a free-generator.
color
What is that aluminum foil for ? :
Обзор доски
https://www.youtube.com/watch?v=tnb8gUifKgk&t=81s
https://www.overunityresearch.com/index.php?PHPSESSID=7v83u0ao3qjdu3ehak895bp3v6&topic=3926.msg93802#msg93802
Using the IR2110 in the push-pull circuit generates a lot of heat in the yoke-transformer circuit and the grenade coil.
It is so hot that you cannot touch it with your hands.
45mm PVC-pipe bends under intense heat.
In my dad's case, the 45mm PVC-pipe was bent more than 10 degrees, so I replaced it with an aluminum pipe.
PVC pipe turns yellow in strong heat.
The picture below is the one that was stopped while restoring the curved one.
That's why the member in the video above installed a support under the grenade coil as a temporary measure to prevent the PVC-pipe from bending.
Aluminum foil doesn't do much other than act as a kind of heat sink.
Some members stress that aluminum affects frequency, but in my dad's experience it has nothing to do with generator operation.
