Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
color
When I read the story backwards, I meet special and strange materials.
Void:
August 09, 2017, 09:21:24 PM
Not entirely because I think we both agree an 'out of the box' approach is worth exploring.
As you have said, its not easy to work out what he is doing, so it boils down to individuals interpretation.
He is not connecting the mains directly to the coil unless it is an outright fake. ;)
Anyway, it seems there is little interest in this any more, but the Daly and Akula circuits
and info are maybe the best clues anyone has to try to go on regarding Kapanadze
type devices.
I would be curious to know if anyone has ever confirmed that Kapandze's coils
are definitely air core, with no ferrite or iron core of any type inside?
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/17655/
color
Void:
August 10, 2017, 01:57:05 AM »
Quote from: Hoppy on August 09, 2017, 09:43:08 PM
I agree, clearly not directly to the raw mains supply unless its an outright fake. I'm thinking in terms of transformed down unrectified mains being subjected to HV pulses. As you mention, its odd that he connects directly into the mains. If the inverter is supplying the mains to a step-down transformer but does not have the energy to start the bulbs, does the direct mains connection trigger the process by heating the filaments to then allow the 'processed' inverter output to maintain a fully lit bank of bulbs. Could the buzzing be an out-of-phase reaction of the grid mains somehow mixing with the transformed mains??
Hi Hoppy. I don't know, but it appears the battery powered inverter that is supplying the 50 Hz, 220v, or whatever they use there,
is the main and only power source needed once he gets it going. It could just be that the inverter he had couldn't supply enough power
at startup to power the whole circuit and the flyback driver circuit at the same time without a temporary boost from the mains to get the
sparkgap going. Not sure at all though. Just going by how it looked to me. :)
Anyway, there seems little doubt that if that setup was genuinely producing OU, that it is a relatively simple setup,
so possibly it is a fairly simple concept behind it once you know what it is. :) Thanks for the chat Hoppy. I will get back to
doing more experiments along these lines over the next while as I find time and see what happens.  :D
All the best to everyone with their experiments...
color
May 31, 2017, 01:40:47 AM
   20MHz is way to high for either the Kacher or the induction circuits.
   Induction circuit should run at something like 15- 27Khz and the Kacher 1-2MHz.
   Don't know you mean by 16f84 20MHz.
The 16f84 is an old microchip, microcontroller look it up it divides the clock by 4 so you have 5 usec blocks in time to play with, you don't have to use 20 Mhz clock you can use any freq you want it just means 20mhz is the maximum clock speed its totally programmable and dead cheap. I think Microchip are now into the satanic darker side of things now like chipping people with the bloody things oil barons and their cronies so I'm told.
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/17250/
May 31, 2017, 02:55:58 PM »
Hi all,
In addition to the input of AlienGrey and zalmoxis, there is no difference what you feed into low frequency part.
The heart of device is the Tesla coil which is making same conditions as pre-lightning in the rain.
I was also told several times by akula and others, the Tesla Radiant receiver (patent US685957 -  https://teslauniverse.com/nikola-tesla/patents/us-patent-685958-method-utilizing-radiant-energy ) is a simple way to detect right conditions when it is near top load of the Tesla coil and the potential on "live" wire is always positive in relation to the ground. No matter what polarity is on the Tesla coil, it never changes on the right frequency with sharp dischage and the right voltage. I was also told by akula, that potential stays for quite long time after Tesla coil is switched off..
It is the electricity harvested from the air charges on those devices!
So here are clues what to look for before going down another rabbit hole with the LC resonances and more complex circuitry.
Cheers!
May 31, 2017, 06:36:41 PM »
Hoppy and Nick,
Yes, it takes years to go through most of possible combinations. But in the end to answer what energy source is tapped to those devices is always from the limited number of choices with the current technology.
And the Tesla system is obvious one here. With additional information from people who made those devices it is getting close to final proper replication. I would avoid promise to show one soon but over time will see what can be done about that...
Cheers!
forest:
May 31, 2017, 10:26:30 PM »
Thunder can occur everywhere but there are places like Colorado Springs where they are more common. Recreating the lightning ?
T-1000:
June 01, 2017, 10:25:50 AM »
Mhm, did my words hit someone's painful areas? The off-topic in response after my post..
We see lightnings every day. Not much people do think how they appear in the first place. Even less people are trying to understand underlaying mechanics before utilizing atmospheric electricity.
Anyway, it is been and will be there, waiting to be harnessed. And in regards to Kapanadze style devices the thruth most likely is just there...
forest:
June 01, 2017, 12:09:23 PM »
I agree. Active supression by flooding thread with nonsense comments. Nice that all is grasping the interconnection between all free energy devices - the energy source.
June 01, 2017, 03:58:07 PM »
hmm perhaps not then.
color
I followed Hoppy's advice faithfully.
Hoppy:
May 19, 2017, 10:06:41 AM »
Nick,
The primary problem is likely to be lack of duty cycle control due to supply rail spiking adversely affecting the TL494. You should see an improvement if you use a separate supply for the TL494 and fet drivers and star ground to the primary power supply. You will need to experiment with chokes once you have gained reasonable duty cycle control. Getting the snubbing right takes experimentation whilst studying the waveforms. As you are finding, its a steep learning curve! As a start, increase the size of your heat sinks and make sure you have good thermal transfer from fets to heatsinks by using new pads or grease.
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/17220/
color
Hoppy:
June 01, 2017, 05:24:31 PM »
Nick,
Free energy is a misnomer as Satans hand will see it done that the common man does not financially benefit from any source of new energy, irrespective of its nature. We could spend many more years searching for Kapas secret and at the end of it, if successful, be prevented from using it.
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/17265/
GeoFusion:
June 02, 2017, 05:44:31 PM »
Hi  all :),
As what T-1000 has posted
the electricity harvested from the air charges is what makes these devices work.
The ions and positrons are abundant around us, on earth and outer space,
our sun and the center sun of our planet produces the charges continuously waiting
to be used in many forms.
Tesla coil is indeed the Heart of most of these devices / Devices which operate on charge / discharge of Hv.
Which Attract and activate these ;).
Lighting is the clear example of it, all the charges that is and create that condition within a device.
Imagine the continuous lighting strike within and siphoning energy from it.
here are 2 videos where shows how important the Kacher / Tesla coil really is.
You will see high voltage being generated at output of the grenade and which is then charged and discharged rapidly
from the caps and which creates the output we all want.
It will give you a hint also what is happening on Vasmus's system ;)
1
https://www.youtube.com/watch?v=LGRS6SVmcoo
2
https://www.youtube.com/watch?v=el1SkfaHmsI
Cheerz to all.
T-1000:
June 02, 2017, 06:37:04 PM »
.. and same with Don Smith devices - https://youtu.be/W7GHqw7d1No
See the video from this angle and his explanations will make sense.
TinselKoala:
May 23, 2017, 06:30:34 AM »
Thanks!
My new videos aren't really relevant to this thread, but this one may be of general interest anyway, especially since it has gotten my trolls to post their 5 thumbs-downs already:
http://www.youtube.com/watch?v=ChV7n0EY2h0
Meanwhile, I've been testing the 494 driver board using a small pot-core stepup transformer and a neon as load. I'm either connecting one end of the pot-core Primary to both drains and the other end of the Primary to the positive supply rail. Or, I'll connect each end of the Primary to a Drain and the Center Tap of the Primary to the positive supply rail.
In the scopeshot below CH1 and CH2 are the Gate signals from the twin 4420 chips, and CH3 is the common Drain signal using the first potcore hookup. (Remember Drain goes LOW when mosfets are ON). I have found that tuning can be tricky, in that sometimes one or the other of the 494 outputs collapses to a spike instead of a rectangular pulse. This may present a problem if one tries to tune without using the oscilloscope.
The Drain Snubbers using 22R 2W + 0.01 uF 1kV  are working well to absorb nastiness that could heat up and or damage the mosfets. I'm using IRF3205 mosfets and they are working well with the loads I have tried. Have not damaged anything in several hours of testing in all kinds of load conditions and current draw. (I have my PSU set to limit current at around 3 amps though.)
I have also installed a switch whereby I can select one of three different Timing Capacitors so I can cover a very broad frequency range. (Not shown on the Layout diagram.)
This is basically the Stalker circuit with the addition of the 1k pulldown resistors for the 494 open-collector outputs, and the Snubbers on each mosfet Drain, and the switch for Timing Capacitor choices.
May 16, 2017, 06:17:13 PM »
Hi Hoppy. How's things?
Any further thoughts from anyone on what might be the basis for the mentioned 'current amplification'?
I know it has been tossed around previously here, but just curious if Kapanadze or anyone else revealed anything further
that might be considered at all 'new' in this regard. Even a seemingly tiny insignificant detail might potentially prove
much more significant than it appears on the surface, and, if the Kapana
justawatt:
May 17, 2017, 11:30:18 PM »
https://www.youtube.com/watch?v=pSNX1wAIMF8&feature=youtu.be              ruslan device watts
https://translate.google.com/translate?act=url&depth=1&hl=en&ie=UTF8&prev=_t&rurl=translate.google.com&sl=auto&sp=nmt4&tl=en&u=http://matri-x.ru/forum/index.php/topic/1769-%25D0%25B3%25D0%25B5%25D0%25BD%25D0%25B5%25D1%2580%25D0%25B0%25D1%2582%25D0%25BE%25D1%2580-%25D1%2580%25D1%2583%25D1%2581%25D0%25BB%25D0%25B0%25D0%25BD%25D0%25B0-%25D0%25BA%25D1%2583%25D0%25BB%25D0%25B0%25D0%25B1%25D1%2583%25D1%2585%25D0%25BE%25D0%25B2%25D0%25B0/page__st__220
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/17205/
Void:
May 16, 2017, 01:21:04 AM »
Quote from: AlienGrey on May 16, 2017, 12:49:31 AM
Ever thought it could be a harmonic of the grenade tuned frequency 'wave' or fraction of it ?
Yes, of course, and such an idea has been discussed here in the past...
I was kind of more wondering if Kapanadze had made any comments about that to stivep or in his
previous videos, or if anyone has noticed whether the length of the earth ground wire in Kapandaze's demos
seems to be just fairly random or not...
Hoppy:
May 16, 2017, 05:51:00 PM »
Good Afternoon to you Grum.
Yes, as you suggest, a non-inductive load would be a good thing for Nick to try in order to test out correct operation of TL494, drivers and fets. Its all too easy to spike and smoke the fets with insufficient snubbing. The Kacher upsets the duty cycle control from the TL494 and also stresses the voltage regulators, resulting in a device that is unstable in operation, with the 'effect' being a primary observation.
Void:
much more significant than it appears on the surface, and, if the Kapanadze devices are indeed real, then the actual effect
people are looking for may possibly be much simpler to produce than it might appear from Kapanadze's devices.
That's my hunch anyway... :)
All the best...
Hoppy:
May 16, 2017, 06:39:54 PM »
Hi Void,
Unfortunately no further thoughts, other than a strong rumour on the fora, apparently arising from an alleged comment made by Kapanadze, that the device is primarily electrostatic based, rather than electro-magnetic. However, don't ask me for the source, as I cannot find it again.
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/17190/
