Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
0 Members and 25 Guests are viewing this topic.
color
아빠~..............음..................... 엄마가 잠만보제 아빠.
[단독] 러시아 푸틴, 이스라엘과 유대자치주 독립 합의...'아시아의 이스라엘' 현실화될까?
https://www.youtube.com/watch?v=9qUafwt97CQ
종교적 정신이상은 천국보상받기 어렵다.
Jewish Autonomous Oblast
https://en.wikipedia.org/wiki/Jewish_Autonomous_Oblast
color
뭐쳐먹을거있다구 슬금슬금 기어오나... 8) ::) 8)
color
북괴땅은 내땅 하늘땅 각개별땅 아빠.
seychelles
SO COLOUR YOU MUST BE LONELY HERE. WELL COLOUR YOU ARE ENDEAVOURING IN
PERSEVERING ON THIS CRUSADE. BUT PLEASE ENLIGHTEN ME ON THE PRINCIPLE OF
THIS KAPANAZ PROJECT. MY UNDERSTANDING IS YOU ARE TRYING TO EXTRACT ELECTRICAL
ENERGY FROM AN ASYMMETRIC CAPACITOR WHICH IS THE EARTH AND THE IONOSPHERE.
AND TO DO SO IS TO USE THE PRINCIPLE OF STANDING WAVE IN CONJUNCTION WITH CURRENT
DISPLACEMENT THEORY.
color
Quote from: seychelles on January 28, 2022, 12:13:14 AM
What is Electric Charge and How Electricity Works | Electronics Basics #1
https://www.youtube.com/watch?v=iqVtGNQAC2E
물과 소금은 어싱(Earthing)의 핵심이다..
https://www.youtube.com/watch?v=qpyB_1gpqAQ
https://www.youtube.com/watch?v=zRdiR5FVJ94
vasmus - СЕ генератор - часть 6
https://www.youtube.com/watch?v=RLBgMxVTVy4
The model in which the negatively charged electron revolve around the positively charged nucleus was first proposed by Neil's Bohr called the Bohr model. In this model, Bohr proposed that electrons revolve around the nucleus, and the electrostatic force of attraction between the nucleus and electrons provides the necessary centripetal force which keeps the electrons in the circular Bohr orbit.
https://www.quora.com/Since-the-nucleus-of-the-atom-contains-protons-which-have-a-positive-charge-and-around-the-nucleus-are-orbiting-electrons-with-a-negative-charge-why-dont-electrons-collide-on-to-the-nucleus-since-there-is-an-electric-force-that-pulls-the-electrons-towards-the-nucleus
Among the materials on Earth, there are materials with a high positive charge ratio and there are materials with a high negative charge ratio.
When two substances meet, electricity is generated.
However, what we want to know is not the relationship between polarized materials, but how to make the alternating current generated by the transformer and the tesla or kacher react with the ground charge.
A typical AC electricity from a utility draws its charge from ground.
The principle that alternating current draws charges from the ground occurs at the intersection of the N and S poles.
When the N and S poles cross the electrons of the copper wire at high speed, the electric charge of the ground reacts to the copper wire.
When the voltage is low, it can attract a charge from the copper wire and close to the ground, but
When the voltage is high, it can attract electric charges far away from the copper wire.
It is not possible to attract electric charge from a distant place just because the amount of current is high at a low voltage.
A high voltage and low current does not mean that charges from a distant place can be drawn.
The reason that 220V/3A alternating current can draw charges from the ground is because the proper voltage and amount of current make the ground charges react.
The reason for using a tesla or kacher that generates a high voltage is to draw electric charges from afar.
Lightning amplifies the amount of current when the negative charge of the cloud meets the positive charge of the ground,
The generator is a difference in which the amount of current is amplified by the high frequency that penetrates the insulator.
Now only the methodology remains.
How can I make a generator that generates 220V/3A~2000V/3A?
환속 후 세속에서 성공했는데도 다시 수행을 시작한 이유 | 김연수 한양특허법인 대표 변리사 2
https://www.youtube.com/watch?v=cBpikByRPDA
어디서 이런 황당한 짝퉁 인터뷰니.
Ps,
Some members have a negative view of this principle.
They say it could affect the Earth's ionosphere, causing environmental changes and other catastrophes.
The electricity produced by all power plants in the world is alternating current.
Essentially use grounding.
It is also great to prevent electric shock accidents,
Above all, if grounding is not used, power is reduced due to the resistance generated in the conductor, and the efficiency of AC power generation is very low.
To prevent this, [Grounding] must be buried in the ground at a certain distance.
340,000V high-voltage transmission towers are all over the world.
340,000V high-voltage transmission tower connected to the ground does not affect the earth's ionosphere,
Does a kacher of 2000V affect the Earth's ionosphere?
I understand that members who are ignorant of electricity or electric laws ask about the generator principle, but
It is incomprehensible to me that members who do not know the size of numbers, arithmetic, and mathematics ask about the generator principle.
