Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
color
NickZ :
Re: Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
« Reply #19632 on: October 21, 2013, 09:50:58 PM »
  Acca:
  We have tried to contact Akula concerning the working principals of his previous device.
He did not answer my e-mails, or to MenofFather, and although he did communicate with T-1000 through Skype, several times, there were no further discussions after a certain point.  That does not mean that it is still impossible to do so, at this time, but I'm just relating that an effort has been already been made to do so in the past. And since Akula may not speak English, or at least not well, this is one of the reasons that we have not continued to pursued this by non-Russian speaking people from this or the other Kapanadze's cousin thread.
  Concerning long earth wires:  Akula has shown a long ground wire, going to the saturated wet area that's about 8 to10 meters away, as well as having no earth ground, at all. It looks like both ways are possible, to have some results, at least if what we see is true. But, there may be an advantage to having a long wire, instead. Which may also be working as a type of antenna, as well as a ground. This all needs to be tested, as well as the different cores, bifilar, or not, winding methods, resonance points, feed-back methods, etz...
That is what we are trying to do.
https://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg374316/#msg374316
color
magpwr :
« Reply #18930 on: August 27, 2013, 12:20:40 PM »
Quote from: ariovaldo on August 26, 2013, 10:23:36 PM
Good afternoon Hoopy....
Yesterday I tried some setups that I planned at the begging of the week,  using MOT with 3 turns as output, connected to other one with 10 turns as input and 120 turns (original from the MOP) output. I used thyristor, diode, capacitor in every conditions that I could do and I just noticed one anomaly that I will purchase some test instrument to confirm that. This "anomaly" was some gain in light intensity associated to current decrease, using a thicker cable as output. (I was using 10 turns of 8 AWG and start to use 6 turns of 8 AWG plus to 2 turns 1/0)
I didn't give up and I will be testing some more points using transformers, thicker wire connected to the grid / inverter and most important, try to create a resonance.
Take a look in this attachment: it is not OU.
It is a simple movie where I used old TV yoke, feed by 12 volts AC( square wave) with a variable frequency. There are 2 wingdings  Primary with 17 turns, 10 AWG wire, secondary with 42 turns of 14 AWG. The secondary was wound in 1 ½ inches aluminum tube with a slot and the primary was wound in the middle of secondary.
What is important is to use the capacitor to create a resonance in the secondary, so the light will be in the maximum intensity.
http://www.youtube.com/watch?feature=player_detailpage&v=Dl6bd-w1VIE
Hi ariovaldo,
It's a good start with the yoke experiment.I also liked the sountrack kinda reminded me of "mission possible" movie soundtrack. :D
This video i have attached might give you some insight related to yoke resonance which might help you in your experiment.
Attached link- Pulsing a Yoke Coil 6 -Please checkout other yoke  related video from this youtube user.He did mentioned T-1000 in video.Interesting.
http://www.youtube.com/watch?v=FR5YDawEBu8
https://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg369103/#msg369103
Yoke-The beginning of winding coils on transformers may be from this man's experiment.
It would be a coincidence rather than someone ordering it...
If not,,,, ??? ;D
color
Zeitmaschine :
« Reply #17945 on: June 17, 2013, 09:38:10 PM »
Quote from: captainkt on June 17, 2013, 05:49:41 PM
When I tried to put connection between transformer and inverter the inverter blew up. Back to drawing board for me, so much for free energy I have spent thousands.
Because most likely the inverter is not an inverter. It's a converter, converting potential-free pulsed DC coming form a rectifier back to AC (by means of synchronized thyristors). The input side of the rectifier can be connected to an inverter (and car battery) like seen in 2004 and green box video, or it can be connected to an insulation transformer like in these presentations: 1, 2, 3
If the primary side of the transformer is connected in parallel to a capacitor (LC circuit) then a short impulse from a 9V battery will create also a sinusoidal wave which can be used to start the device if internally back-looped.
Now what could happen if we connect potential-free pulsed DC to ground via a large self-inductance (maybe in combination with a capacitance)? Could this large self-inductance be suitable to capture electrons from earth which then amplifies the output current?
Just speculating, don't want to blow up my equipment (yet). ;D
But at least nothing of this contradicts what can be seen in all the Kapanadze and Stepanov videos.
BTW: It's impossible to start a factory-made (off-the-shelf) inverter with a 9V battery. That means whenever TK starts his device with a 9V battery there is no inverter (don't think he soldered his own one), just a sinusoidal impulse. Furthermore that means there are three different types of TK devices: One type works with an inverter and a car battery, one with an insulation transformer from grid, and one with a LC circuit triggered by a 9V battery.
https://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg363357/#msg363357
