Stanley Meyers revisited
Started by Alfang, December 16, 2006, 11:32:06 PM
popeye68
Hi Kentoot ,
i think the alternator is a very important part of the Meyers setup
and maybe the effect is not reached without it...
Bob Boyce had succes with his cell's also due to an alternator issue;
http://www.overunity.com/index.php/topic,2637.0.html
His posts have vallueable information , also on cell preperation etc.
on http://www.oupower.com/phpBB2/viewforum.php?f=1
you can find more nice info , also from Bob Boyce
kentoot
Thanks for the info Popeye, I'll look into it. It's a lot to digest :).
Yes, I agree that the alternator is very important. It's important because the alternator is able to deliver the necessary pulse to the cell. In fact, alternator, in many ways, is similar to a transformer. Why ? Because an alternator has wire coils (basically inductors) that generates the output voltage, just like a transformer secondary winding. In order to generate the output voltage, that coil receives a changing magnetic field. In an alternator, that changing field is from the rotating magnet on the rotor, while in a transformer, it's the primary coil.
Most alternator have more than 1 phase, this is to minimize the ripple when converting to DC (using bridge diodes, got modified in Bob Boyce's case ??). Also the rotor field is usually adjustable, to regulate the output voltage. Nevertheless, the concept of an alternator and a transformer is the same. I guess you could say that a transformer is some sort of solid state version of an alternator.
keithturtle
From what I've read, the alternaotor can be replaced by electronics, specifically hi-rate switching MOSFET transistors.   Apparently these weren't as developed whenever Stan was doing his early work.   One patent dated 1983 shows an elaborate mechanical device capable of producing the desired D C pulses needed to make his water fuel cell work.
Turtle
Soli Deo Gloria
kentoot
Yes, I agree, most likely the alternator role can be replaced with a switching device, such as MOSFET, and a transformer. I'll try my luck with the transformer & MOSFET.
h20power
Hi Everyone, this is too let everyone know I am still alive ;D
Newman's technology and tesla's works really help on understanding just what is going on.
This is a video too let you know just who is in charge of the planet: http://video.google.com/videoplay?docid=5547481422995115331&q=zeitgeist&total=662&start=0&num=10&so=0&type=search&plindex=3
This is a video of the work I am aiming at right now with Meyer's technology:
http://www.dispatch.com/dispatch/content/local_news/stories/extras/0707/hydro.html
I am short on funds as always so progress is slow, but I am makeing good head way in my understanding of it all 8). On that "Scam" video it is nothing more than an attemp to brain wash you with flashing images of the word, if one reads the court files on Stanley's court drama it is very clear that he was railroaded. They even put salt in it to make sure it wouldn't work, and refuse to let stanley speak. It was a joke of a case, and the Judge should be stripped of his title.
As for the coils all of them are bifilar wond, but once you read the Newman pdf. file you might, just like me, see the light, and know the "why", for without the "why" you are lost, just trying to copy, when it demands that you understand it.
I hope all of us trying the best of luck, and God speed to our sucess
