IEC Earth Engine First Magnet motor installed in Las Vegas
Started by ramset, March 14, 2019, 11:35:40 AM
hartiberlin
Hi Ben, welcome back. Good to see you again.What abiout your Thomas motor ? Did you try to scale it up with the Orbo effect yet ?
Sorry for this offtopic question...
Back to the IEC Earth Engine:
Also I got more and more the view, that the IEC Earth Engine is not working...Surely it would have been presented in a different way, if these motors could really drive KWatts loads...
Maybe they just have a motor, that generates just a few MilliWatts or Watts and they just let the big flywheel accelerate over a long timeframe  from this low magnetic power input and then use the stored energy in the flywheel to generate some power from it...
But I doubt they could provide a few  KWatts for longer than a few minutes...
Vortex1
Quote from: k4zep on May 02, 2019, 01:37:37 PM
Very simple to verify.  Put a 500 watt resistive load on the Alternator.Watch the RP'm. if they stay constant, Rat on...If they drop till it stops.....bah humbug.I guess that would be too easy!
Ben K4ZEP
Yes that would be too easy. And why not a small tabletop model continuously lighting a small incandescent lamp, as magnetics are downwardly scaleable. Make it such that there is no possibility of hidden compartments for batteries and let experts disassemble it after a lengthy run.
Oh I forgot, common programming technique is to dazzle the eyeballs so you need to make it very large e.g. Bhoudini's ferris wheel. A lot of spinning black and yellow safety tape helps with the trance induction, then the hypnotic spell is complete, just sign on the dotted line.
k4zep
Quote from: hartiberlin on May 02, 2019, 04:22:11 PM
Also I got more and more doubt, that the IEC Earth Engine is not working...Surely it would have been presented in a different way, if these motors could really drive KWatts loads...
Maybe they just have a motor, that generates just a few MillieWatts or Watts and they just let the big flywheel accelerateover a long time from this low power and then use the stored energy in the flywheel to generate some power from it...But I doubt they could provide a few  KWatts for longer than a few minutes...
Off topic is OK with me.  It is good to be back.  The Thomas motor is just sitting on the shelf for now.  I never pursued the switching effect in it any further.  Maybe someday!
Also the "Put Put" motor that showed some anomalous behavior at very high voltages, but again, maybe later.
As most on the list have built pulse motors, shifting field motors, shielded motors, etc.  What we are seeing is not all that newand from the long term results that we see, it is easy to get a jaded view.
IF with a 20 watt average input to the governor and magnetic switching or mechanical motor driven switching, etc., they can get 500 watts out continuous with the "Plastic" motor, or 5-600 Watts in and KW out with the larger motors, they will have something.  I don't think they have demonstrated that to us here.  If the flywheel in the small motor can generate the 500 Watt output for hours at a time into a regulated circuit/charger/inverter, etc. without the flywheel slowing down they will have something.  But as my last name is "Thomas", I'm a show me.  I see some beautiful work INTO a neat pulse form of motor but I have yet to see confirmed OUTPUT from the same device.  Am I missing that mechanical switch as seen on the plastic motor vs. the BIG motor?
Someone on the list said to Google "Dennis Danzik" !  I just did....Do you like to read large PDF files???  Make your own opinions.
RespectfullyBen Thomas, K4ZEP, Worlds Smallest Lab
hartiberlin
We really need someone with good technical measurement knowledge to go there and have a personal lookand see what the real output under load is...
Is no one living near the shooting range installation or near Scottsdale ?
Please let me know.Maybe we can arrange a visit via Karl Walsh for you..
Regards, Stefan.
hartiberlin
In less than 3 days they will have a LIVE Demo 24/7 via Livestreaming here:
http://earthenginelive.com/
They write:
The World's First Magnetic Propulsion Engine was developed by Inductance Energy Corporation and will be streaming LIVE 24/7!
"Crystal" is a fully transparent laboratory scale model of the Inductance Energy Earth Engine. Crystal is driven by Magnetic Propulsion, which is the science of moving a mass (such as a flywheel, vehicle, elevator) in a rotator reciprocating, linear, or vertical direction soley by means of controlling permanent, imbalanced magnetic radiation (field). Using the repulsion (opposing force) as a fuel source, the Inductance Energy Earth Engine, driven by magnetic propulsion pushes large, heavy flywheels with zero-contact. Inductance Energy zero-contact drive system allows the Earth Engine to operate variable speed transmissions, drive shafts, reducers, and other devices without the requirement of gears, sprockets, chains, or belts. This provides a near friction-less connection between power source and the final selected device, such as a pump, compressor, or generator.
Inductance Energy is proud to display Crystal to the world on this Live Streaming broadcast here at EarthEngineLive.com.   If you are looking for more information about this world changing technology, visit us at ie.energy, or sign-up here to be added to our communication list.
