science and prediction
Started by lancaIV, May 20, 2019, 06:01:34 AM
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=http%3A%2F%2Fwww.perpetuum-mobile.de%2F
Which has been  a.  in theory b. in practize
the efficiency from ma(s)chines: converter/transformer/motor/generator : cinetic/mechanical or electrical
                                                        1775/1875/1975
                                                        and now 2019  ?!
                                                       > 0% v =<> 100 %. !?
Calori(e)= heat units
to Joule
https://en.m.wikipedia.org/wiki/James_Prescott_Joule
to Watt
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fde.m.wikipedia.org%2Fwiki%2FJames_Watt
Calori to Joule to Watt converter :  https://www.rapidtables.com/calc/electric/Watt_to_Joule_Calculator.html
Active/passive energy :
a. Physical ( classical + quantum-physics) input  b. technical input
    physical( theoretical thermodynamic output ) technical ( maximum -  constructive losts) output
I. 1 glas(s) CO2-less water + silver spoons converter : hydrolyse : bubbles = hydrogen/oxygen splitt
hydrogen collection + cold inflammation = heat in calori
oxygen ? energetic source. ?
II. 1 glas(s) CO2 -less water + chemalloy array : hydroyse : bubbles ......
III hydrogen to steam engine/ Sterling engine
IV. steam engine/Sterling engine with electric generator couple
1775: ~  James Watt steam engine conversion efficiency improvement
               coal to heat conversion efficiency
              heat to steam conversion efficiency
              steam to mechanic power
             ( mechanic to electric power)
2019 solar-heat e-turbine efficiency ? = <> 100% : physical or technical input/output ratio  definition ?
What is " efficiency and/or C. O. P. " related to. : http://alt-sci.ru/en/wiki/Vortical_transformers
6A-6H : is there a need about a mathematical "DC to pulsed DC to AC voltage and DC to pulsed DC to AC current "- converter. ?!
DC = permant             pulsed DC and AC = periodically
Fix speed/variable speed
When a 1000 Watt nominal generator by nominal 1000 RPM delivers 1000 Watt
why the same generator delivers.         by.                 500 RPM.                 125  Watt.   Max x ( 0,5x0,5x0,5)
        the same generator delivers.         by.                 100 RPM.                     1.  Watt.   Max x ( 0,1x0,1x0,1).      ?!?!?!?
          [0091]- [0094]
https://worldwide.espacenet.com/publicationDetails/description?CC=US&NR=2012256422A1&KC=A1&FT=D&ND=3&date=20121011&DB=EPODOC&locale=en_EP#
Inverse : input to e-motor !?!?!?
A. DC input ~ torque x RPM.  : 1/4. 1/2  1/1 load
B. pulsed DC or AC input ~ torque x RPM 1/4 1/2  1/1 load
1976-2011 technical work and application :
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=&IN=Richard+fradella&CPC=&IC=
The motor and generator performance question now implementing here :
https://patents.google.com/patent/US20110097209A1/en
                        Figure 12
input/output ratio.        a.< 1        b.=1.    c.> 1.  break-even ? C.O.P. max point / output max point
onepower
Ianca
Keep up the good work, can't understand a damn word your saying or where your going but... you are consistent.
Quote from: onepower on October 21, 2019, 12:57:26 AM
Ianca
onepower,
physics theory is more than 1+1=2  !
For searching between linear and progressive positive or negative results,by linearity or progression, we apply
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fde.m.wikipedia.org%2Fwiki%2FMengenlehre
When we calculate 1+1= and we do not get 2 but < or > 2 where is the"syntax"  difference  ?
How to translate physical overunity( output/input ratio > 1) in a mathematical formula. ? PRAXIS ZUR THEORIE
I am only in search for the right " theorem" answer. ! ;)
Beside the Fradella generator "asymmetrical" output also Flynn magnet actuator results( static device) andT.T.Browns' electrostatic devices ( beside-effect: Ozone-generation) and Kanarevs " pulse power"- experiments making part !
Lorentz/Einstein : e= mcv2.  Why Tesla : e= tcv2. by logic : m = t ,easy to write like 1+1= 2  :)
                            By which clear arguments  ? Have you, onepower, a simple answer. ? ::)
                           I will wait persistent for your scientifically comment. ! ;)
One answer could b : based by Schroedingers "Miau-Miou" chamber question;:
  t= time- Universum. or m = ( specific) matter- Universum
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fwww.spiegel.de%2Fplus%2Fist-es-moeglich-dass-es-unser-universum-gar-nicht-gibt-a-00000000-0002-0001-0000-000159189655
But this are only entertaining questions, my main object is the cheap electricity/kinetik energy delivering device. !
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fwww.n-tv.de%2Fpolitik%2FBund-und-Laender-erzielen-Klima-Durchbruch-article21460042.html
From 10 EUROS/ton CO2 actually to 55 EUROS/tonCO2 certificate costs in 2025 in Germany
If the use from 1 KWh grid- electricity in Germany by given Sources-mix emits : 478 gram CO2
the CO2 costs part by 10€/ton ~ 0,478 €Cent/KWh grid- electricity
the CO2 costs part by 55 €/ton ~ 2,629 €Cents/KWh grid-electricity
To show what this would mean for the U. S. A market.  :
actually the average US-b2b electricity KWh- price : 5,5 US$cents
55 Euros/ton certification costs increase by similar CO2-emission value ( coal/nuclear/wind/water ....) per KW. ~
                2025      US-b2b average electricity costs : 8,5 US$cents/KWh
https://www.spritmonitor.de/de/berechnung_co2_ausstoss.html
     Fuel combustion
1 litre gasoil ~ 2,64 Kg CO2
by 10 €/ton :     2,64 €Cents per litre
     55 €/ton :   14,52 €Cents. per litre ~ 1 €Cent/KWh chemical
The estatal CO2 tributation is then higher than the costs of the fossil product  fob oil/gas field or e-generator !
But we have now the SELF-production price maximum for hydrogen and off-grid electricity generation. :
                                                         in Germany 2025
                                                     Hydrogen : 1 €Cent/KWh chemical
                                                    Electricity : 2,629 €Cents/KWh
For him easy challenge benchmarks :          https://judbarovski.livejournal.com/
So the US-b2b market has in future three alternatives :
stay in their 5,5 USD cents/KWh price and (national/global)climate changing politics
let increase the electricity price by 62,5 USD/ton CO2 certification costs accumulation : +- 8,5 USDcents/KWh
decentralize power generation and use SELF-costs price level electricity plants in the < 3 USDcents/KWh range
CO2-free energy2electricity conversion
( with the CO2- absorption and to synthetic FT process gas/fuels production possibility )
http://www.dotyenergy.com/
Windfuels/waterfuels/solarfuels : source-/locality- independent gas-/liquid power production
Windhydrogen/waterhydrogen/solarhydrogen
Conventional fossil gas fuels : 100 units CO2
Synthetic gas/fuels                  - 50% CO2
Arakelian process.                     - 82,5% CO2   7 units hydrogen/ 1 unit fuel ( fossil/bio/syn)
NH3,Ammoniak.                           CO2- free.
Question : CO2- "temperature effect"-aequivalent from electricity( Plasma-gas) and hydrogen as GHG. ?
The local GHG-effect from electricity some also call : electric heating  8) TEMPERATURE INCREASE
Vapor/waterdrops  is defined as GHG : CO2- aequivalent ?
is the hydrogen generator emission same cold as exhaust like as generator input source  ?
Hydrogen-on-demand emission in CO2-aequivalent units. ?
    Expansion energy = GHG-effect ,giving away "compressed energy = density"
Scientifical AXIOM !  REALLY. ? 1 KWH X = 1 KWh Y
Has 1 KWh "light spectrum= radiant energy"  electricity  a minimum/maximum ( EINDRINGTIEFE,ABSORPTION/REFLEKTION)
                              +- 1 KWh ( molecular)  up to 5 KWh( atomar) heat "= temperature increase " potential. ?                                                       Hypothesis : Anti-/Thesis
https://www.google.com/search?q=matschiner+infrarot&ie=utf-8&oe=utf-8&client=firefox-b-m
Scientifical/commercial disputation:
                      DE chemistry docent/Uni-Prof.  against CH-virtual modell-students study
           Physical   "catalysis: :de-/ac-celeration" use :   STIMULATION as process of  L.A.S.E.R. or M.A.S.E.R.  ?
                                   THERMO-DYNAMICS
Is the sun IR /UR radiation spectrum in change and with greater influence by parallel Earth magnet field strength decrease ( shielding effect) ?
Earth surface: land + water. ; water dehumidifying/vaporizing enthalpy energy
http://www.iwilltry.org/b/heat-your-home-with-a-dehumidifier/      "Its all about enthalpy"
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fm.spiegel.de%2Fwissenschaft%2Fnatur%2Fmount-everest-wetterstationen-messen-verblueffende-uv-werte-a-1301499.html
Temperature ( in the shadow, dry, windfree measured)
Temperature( with all light spectrum, dry-wet, windfree-windy measured)
physical temperature
physiological temperature
10° k and more temperature spread
Energy converter
and the difference between 1 KW and 1 KWh
https://www.researchgate.net/publication/301905364_Experimental_study_of_energy_harvesting_in_UHF_band
                                           7,7 mW      = 0,0077 W    or   0,000077 kW
so for permanent 1 KW output 130.000 units are needed ,24 KWh per day ,8766 KWh per year
                                  130.000 x Figure 11 unit : costs per unit ? sqm area ,cubic-mtr volume ?
https://contest.techbriefs.com/2016/entries/sustainable-technologies/6390
A nominal generator, approximately the volume of two men's shoe boxes, including the battery and control module, can supply extraordinary output.. Even operating at a low frequency of 400 hertz, the net induced voltage is +/- 8.4Kva/sec, (which is an hourly rating of 30.2Mva/hr (40,500Hp)). For comparison, power plants generate from 375 to 758 Mva; a wind turbine generates 2-3 Mva; a large heliostat may generate 280Mva..
more detailed information https://patents.google.com/patent/US8847720B2/en
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=15&ND=3&adjacent=true&locale=en_EP&FT=D&date=19881020&CC=WO&NR=8808220A1&KC=A1
To clarify the operation of this embodiment according to the invention, the following dimensioning of the transformer windings is given using Figure 17 as an example,
the iron cores being dimensioned in accordance with the manner usual for transformers:
- winding 81: 1000 windings, 220 V/50 Hz, 5 A at full load;
- winding 82: 1 winding, 5000 A;
- winding 84: 1000 windings, 5000 A;
- winding 85: 1100 windings, 4500 A, 220 V/50 Hz.
From the above example it is evident that, with a coil 82 having 5000 ampere windings, a flux variation of 5000000 ampere windings can be generated with the superconducting coil 84.
Accordingly, a generated power of 990 kW can be drawn from the terminals 89 for a power supplied to the connecting terminals 88 of 1 . 1 kW, and this corresponds to a power gain of approximately a factor of 1000.
In the variant indicated in Figure 18 of this fourth embodiment, a two-phase system has been assumed. In a further variant of this embodiment, the latter can also be constructed according to a three-phase system. In the above described variant, a mains frequency of 50 Hz has also been assumed. These embodiments may, however, also be used for other frequencies.
                                                        990 KW out and 1,1 KW in                          to commercial  1/1000          0,99 KW out and 0,0011 KW in
Without doubt such devices will become in future conventional
https://en.wikipedia.org/wiki/Magnetic_flux
https://en.wikipedia.org/wiki/Ampere-turn   Ampere- or Weber-turns as defined force : https://www.merriam-webster.com/dictionary/ampere-turn
                            superconductive coil winding 84 : 5000 A x 1000 turns = 5000000 A-T or W-T magnetic flux force
                             the relationship coil 81 output to coil 82 in-/output to superconductive coil in-/output 84 is the "internal process effect"
                                                      magnetic flux force compression and expansion
                      This to MEMS-production condition https://en.wikipedia.org/wiki/Microelectromechanical_systems
