New version of flotation device
Started by Floor, May 31, 2019, 03:03:00 PM
Floor
I had previously thought that gravity power had been explored suffuciently and also
that gravity was simple enough to expect there would never be a gravity powered device.
I gave it another shot, and saw a way to loop it O.U..
This presentation is that sucess.  Some seemingly impossable obsticles
and the a eurika, and then a WOW
check it out
         cheers
            floor
Floor
@ At all readers
I cleaned up / added more detail to the flow diagram / drawings and added a minor detail to the
written explanations page.
      floor
Floor
QUOTE from a users personal message
"It's the gravitational potential of the small amount of water that rushes in to fill the space left by the float as it leaves the bottom of the tank. So, when you rotate the tank, you actually have to perform some net work to also rotate that additional amount of water through its increased vertical displacement. Though it's a VERY SMALL amount of vertical displacement, it's still not zero, which I think you need it to be for the idea to work." END QUOTE
      Thanks very much for your observations / comments.
Your observations would be correct except that.
      9.  All / each action is a start / complete / stop
        action.
        There is no rotation untill after the float is stopped
        / latched / held at the center of the float tank.
While the float is at the bottom, the tank is unbalanced
While the float is riseing, the tank is unbalanced.
While the float has stopped at center, the tank IS IN BALANCE.
Rotation occurs only while the float is at center height.
Sorry that my diagram doesn't state / detail this.
Thanks again for bringing this oversigt forward.
                   floor
Quote from: Floor on June 02, 2019, 08:28:53 AM
That is partially true. In step 6 to 7 of your illustration the float is outside and the tank is no longer balanced so it will take work to rotate the tank as it has become bottom heavy.
