New version of flotation device
Started by Floor, May 31, 2019, 03:03:00 PM
Floor
@All readers
I think it is sometimes a responceability, to keep a topic up,
when it was a fail, and so, for one last time I am posting
in this topic.
   click here
https://overunity.com/18234/new-version-of-flotation-device/msg537516/#msg537516
    This is just the way we do it here @ the over unity.com forum.
              best wishes
                       floor
Low-Q
Quote from: Floor on May 31, 2019, 05:49:03 PM
I'\'m looking for some one to find an error in this.
        floor
Regarding this figure at https://overunity.com/18234/new-version-of-flotation-device/dlattach/attach/173024/
From operation 6 to 7 when the container rotates 180 degrees, you also lift the fluid inside just as much as the thickness of the floater. Because as the floater rises, the fluid flows down, making the container bottom-heavy.
Even if it doesen't take energy to displace nothing as the floter is pushed back in at the bottom, the work required to complete the operation is when the device rotate 180° from step 6 to 7.
If no work is being done during this rotation, you must descend the whole device by the same distance as the floaters thickness for every 6-7 rotation.
Edit: I see now that the problem has already being addressed...
Vidar
Floor
Thanks Vidar !
peer review rocks !
And so here is the New floater fix.
Floor
@ all readers
This embodyment flops as did the last version, and for prety much the same reason.
               fllor
