New version of flotation device
Started by Floor, May 31, 2019, 03:03:00 PM
Floor
This particular device
Gravity does most of the work.
Simple design.
   but an
expensive build.
One versions  lifts 565.7062 pounds of weight 10 feet into the air.
A variation lifts 565.7062 pounds of weight 20 feet into the air.
Any amount of weight and any height can be achieved within the limits of
what the supporting structure can bear.
          Its what we do here at the Over Unity.com forum.
                       thanks for you time
                                        floor
codwell
In step 6, you cannot turn the system back, because the the bottom will be heavier than the top. The bottom has extra water between the rods, the top hasn't, it's now just air. You have to look the weight at the same levels, but not just inside the container. The device won't work, it's not balanced on the centerpoint in step 6.
Floor
Thank you Codwell.
Yes not balanced in step 6
     It fails at step 6
Back to the drawing board.
               floor
Floor
Quote from: codwell on July 25, 2019, 02:54:14 AM
Thank you codwell
          floor
Floor
Quote from: Floor on July 27, 2019, 01:05:36 PM
Thank you codwell
          floor
