New version of flotation device
Started by Floor, May 31, 2019, 03:03:00 PM
Floor
Floor
revised calculations 3  (there were bad calculations in versions 1 and 2)
the energy density is, as should be expected very low, because gravity is
a weak force.
assume:
float = 3 meters length by 0.33 meters radius.
approximate 10 feet by 1 foot
cylinder of 0.33 meters diameter or
0.165 meters radius  by 3 meters length
=  0.25669285714285694 cubic meters of water.
0.2566 cu meters of water = 256.6 kilograms of weight or
565.7062 pounds of weight.
256.6 kilograms = 2516.3864 newtons.
assume :
float chamber interior is 10.5 meters height, by 10.5 meters width,
by 0.5 meters depth into the page.
this means that the height of the lifting of the float
=  10.5 meters minus 1 float cylinder diameter.
              this is = 10.5 m - 0.33 m = 10.17 m
the float is lifted to a total of twice this distance
    10.17 m x 2  =  20.34 m  total height of the float rise
2516.3864 newtons x 20.34 meters = 5214.899376 joules of energy stored
as weight of the float external to the fluid chamber.  OUTPUT
assume:
it requires 25 kilograms of force or  245.1663 newtons, over a displacement
of 3 meters to INSERT the float.
               245.1663 newtons x 3 meters = 735.4989 joules of work
of 3 meters to REMOVE the float.
735.4989 newtons x 2 = 1470.9978 joules input work / energy.  INPUT
assume:
it requires 25 kilograms of force over a distance of 0.33 meters to initiate
/ accomplish a 180 degree rotation of the device.
25 kilograms =  245.1663 newtons
245.1663 newtons x 0.33m = 80.9048 joules of work
there are two 180 degree rotations during each complete cycle.
80.9048 joules x 2 = 161.8097 joules           INPUT
1470.99 joules input + 161.8097 joules input = 1632.7997 joules
                       (previously in error)
5214.89 joules of energy stored as weight of the lifted float, while
5214.899376 joules of energy stored - 1632.7997 joules total input
= 3582.0996 joules                              ENERGY YIELD
assume:
a slow operation time to store that energy (not to use it) of 2 minutes
3582.0996 joules per every 2 minutes =  1791.0498 joules per minute.
1791.0498 joules per minute =  29.85083 joules per second or in other
words 29.85083 watts
         (1791.0498 joules / 60 seconds =  29.85083 joules per second)
conservatively arrived at, this is 29.85083 continuous watts gained as
output power
                     or
29.85083 continuous watts if used for 1 hour =  29.85083 watt hours
                    and this is
716.41992 watt hours if continuously used for 24 hours
                   and this is
5.0149 kilowatt hours if continuously used for one week
                   and this is
20.0597 kilowatt hours if continuously used for one month
                   and this is
240.717  kilowatt hours if continuously used for one year
probably actually about     3      times  this amount of energy.
Floor
@ All readers
The designs and methods I have presented in this topic and which are novel,
are given into the public domain.
  floor
Floor
Gravity does all of the work of the lifting in this design.
Then the lifted opject falls.
               floor
Floor
@ All readers
There is second version of a sucessful gravity based design (presented byCadman)
@ https://overunity.com/18243/cadmans-hydrostatic-displacement-engine/
floor
