The solution !!!!
Started by efusystem, June 10, 2019, 11:48:24 AM
efusystem
Thomas Townsend Brown discovered in 1929 that a charged capacitor experiences a push towards the positive side.
Anyone can check this in a laboratory.
There's only one problem: Electric charges have very little mass, so ...
... according to the Law of Universal Gravitation, this effect is impossible.
This may seem like a paradox, but it is not.
The truth is that we can NOT apply the Laws or Principles of a branch of Physics to the phenomena observed in another branch of Physics (which also has its own Laws).
If we have two objects with different temperatures and we put them in contact, what happens?
What happens is that the object that is at the highest temperature releases energy to the one that has less until the temperatures are even.
Thermodynamics has its own Principles.
It would be a TOTAL absurdity to say that: "According to Ohm's Law this is impossible, because there is no intensity between the objects, the resistance between them is infinite, therefore there can be no heat transfer"
Faraday, in his experiments, discovered that a copper coil reacted to magnetic changes by producing electrical current.
What happens is that copper is a diamagnetic material, and in order to oppose the magnetism of the magnet, it must put its own electrons in motion in order to generate a magnetic field that opposes that of the magnet.
There is no magnetic energy "transforming" into electrons.
There is no kinetic energy of the magnet "transforming" into electrons.
The electrons come out of the copper of the coil to generate a magnetism opposite to the external to it.
The Principle of conservation of energy was enunciated for Thermodynamics, which is the branch of Physics that describes the states of thermal equilibrium.
And when it talks about energy, it refers only and exclusively to thermal energy.
It is NOT demonstrated for any other type of energy (nuclear, electrical...).
But we continue to use it to deny the possibilities of other branches of Physics that have their own Laws.
Making a simple experiment is an added job (no matter how small the experiment).
I guess it's much easier to "seem" smart by saying: "According to the second Principle of Thermodynamics ...", so you don't have to experiment.
I leave a link for downloading a pdf of only 18 pages with drawings and little text.
I have tried to make it as simple and basic as possible to make it understandable by anyone (even if you do not have much knowledge of the subject).
I assure you that what it says is true, is science and of course verifiable.
I would not publish it here if I had not checked it myself.
The pdf clearly explains the principle on which systems like Tesla, Kapanadze, Gray... are based.
It only remains then to check it or deny everything (without checking or reading it).
I recognize that the latter is much easier.
Greetings, Gentlemen.
https://www.4shared.com/office/SSQfWl-iee/EFUSystem.html
https://www.mediafire.com/file/ezikicxbgqvhqmz/EFUSystem.pdf/file
tomd
Makes more sense than anything else I've read.
I think this principle applies to many of Don Smith's devices. In spite of what he said about the electric field resulting in a "heat death".
When I first watched this video https://youtu.be/XkAMNFKjds4 I new there was free energy but lacked the skills to create a suitable circuit.
tomd
NdaClouDzzz
"The electrons come out of the copper of the coil to generate a magnetism opposite to the external to it"
This is exactly what's happening with AC impedance--the copper valence electrons break free from their orbits and come together to impede the externally applied AC. Actually, I don't think the electrons break-free in order to impede. It's just that the positive high voltage provides a greater attractive force to the electrons than does the copper atom, and the +HV in essence tricks the electrons into thinking that they have somewhere to go much like the positive of a charged battery is somewhere for the electrons to go. The impedance comes during the negative phase of the AC cycle when all of the freed electrons in the coil in essence butt heads with the negative of the AC cycle (like repels like). So forced current isn't the only way to get a coil to release its cemf! Electrons want to be where electrons are not. Electron-free positive High voltage is exactly where electrons want to be! So simple yet so elusive to those who are tunnel visioned! BRAVO!!!!!!!!!!!
NdaClouDzzz
Quote from: tomd on June 11, 2019, 04:28:43 AM
What Don was talking about was forcing current into a coil to get it to produce a magnetic field as is traditionally done. You can never get out more than you put in by doing it that way. On the other hand, you don't need to force current into a coil to get it to produce a magnetic field if you use current-free high voltage at the coil's resonant frequency. Just think of how a crystal radio works. The impedance to AC is when your coil is in resonance and producing a tremendous magnetic field; hence "magnetic resonance".
