Magnet motor idea hopefully solved
Started by Low-Q, June 14, 2019, 10:59:32 AM
Low-Q
I fount the 3D-printer quite scewed, so I had to straighten it up. Printing new pulleys with larger gears.
The gears is smaller than the pulley, but that is because the gear can be placed behind the pulleys, and therfor closer to the hub.
This will also allow smaller space between the magnetic chain and the statormagnet.
Vidar
Low-Q
Finished the large sprocket, and three of the geared pulleys.
This is going slow, but it is more to come.
Vidar
Low-Q
Then we start over. Making a larger hub because the chain cannot get stuck between the pulleys.
The pulleys can't just be scaled down because the chain wil not fit.
I have spent more than a kilogram of plastic filament in trial and error. This piece of s**t is hard to align correctly.
New pictures with somewhat progress, but still back to square one.
First picture is the new hub.
Second picture is a sloppy test to see how far out from the hub I need to place the pulleys without pinching the chain between them. Also the sprocket (large ring with teeth on it) is too small. Resizing that one means resizing the pulley-gears accordingly. Puh...this is a pain >:(
Vidar
vineet_kiran
My feeling is,  it is better to verify the working principle first with one unit of chain, pulley and stator magnet.  If it works, ie., if working principle is confirmed, then you can complete the loop. It saves lot of time and your energy (which is not free!).
