Cadman’s Hydrostatic Displacement Engine
Started by Cadman, June 15, 2019, 05:14:21 PM
Floor
@Cadman
Here are some proofs of your principle.
Please find the attached PDF file "Cadman from floor.PDF" below.
Cadman
Floor,
Thank you for sharing your proofs. That took quite a bit of effort to produce.
Sincerely
Cadman
Floor
Cadman
Your very welcome.  Thank you for your design !
I buggered up a couple of the drawings in that "Cadman from floor 3" PDF
sorry ! too much rushing around lately.
Here is the fixed version ""Cadman from floor 3b" PDF
   regards
   floor
Cadman
Nicely done Floor.
This illustrates the difference between the two conditions existing in the up-stroke vs. the down-stroke.
Something that I have failed to convey properly in all of my posts.
Now all that remains is to demonstrate it with the working prototype. Making progress there too.
Thank you!
Respectfully,
Cadman
SolarLab
F.Y.I.
Cadman,
These might be similar to your concept development and may possibly contain some valuable design and construction insight.
(Hydraulic) RAM PUMPS [a.k.a. Hydram]
Design and Construction of a Hydraulic Ram Pump
(including a bit of history and analysis)
Shuaibu Ndache MOHAMMED
Department of Mechanical Engineering,
Federal University of Technology, Minna, Nigeria
http://lejpt.academicdirect.org/A11/get_htm.php?htm=059_070
AbstractThe Design and Fabrication of a Hydraulic Ram Pump (Hydram) is undertaken. It is meant to lift water from
a depth of 2m below the surface with no other external energy source required. Based on the design the
volume flow rate in the derived pipe was 4.5238 × 10-5 m3/s (2.7 l/min), Power was 1.273 kW which results
in an efficiency of 57.3%. The overall cost of fabrication of this hydram shows that the pump is relatively
cheaper than the existing pumps.
Keywords Hydram; Pump; Volume Flow Rate; Power; Efficiency; Impulse Valve; Delivery Valve.
Home Built Hydraulic Ram Pumps
http://www.inthefieldministries.org/jscalhou/Home%20Built%20Hydraulic%20Ram%20Pumps.pdf
"Complete detailed and illustrated instructions from locally available pumping parts - 1" Hydraulic RAM"
How to build a RAM PUMPFrench River Springs
Published on Jul 7, 2018
https://www.youtube.com/watch?v=enBEMgDR3-A
How to Make a Large Size Free Energy Water Pump - Ram Pump
Tradisional Channel
Published on Dec 28, 2018
https://www.youtube.com/watch?v=Esln877z4IE
Hydraulic RAM Pumps - Amazon (examples, descriptions, prices)
Small - $125US - - - Large - $185US
https://www.amazon.com/Hydraulic-Ram-Pump-1-Medium/dp/B072J2Q7L6
Great work and very interesting, thanks!
FIN
