low cost passive foam-home construction
Started by lancaIV, June 27, 2019, 07:20:27 PM
Reminding the Olympia-stadium tect in Munich,
the Atlantis II living in an autonom greenhouse,
the flyingconcrete fisherman-nylon-net as base for hard surfaces ( walls/tect),  http://www.flyingconcrete.com/
the Uni Michigan fibercement invention in the 80' :instead 20 cm wall decrease to 2 cm walls by same strength
this actual article.
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fwww.n-tv.de%2Fwissen%2FForscher-entwickeln-neue-Superfaser-article21458632.html
opens now a huge potential ,
and cheap ~ some Euros/Kg ~ Euros/sqm by given foil density. ?
for "humans living green houses".
Clearly also these polyamid formable to things like :
http://n55.dk/MANUALS/MICRO_DWELLINGS/micro_dwellings.html
"solar passive house" compared to "solar active house"
German/DE market price for 1 sqm pure construction costs :
https://www.energieheld.de/blog/das-passivhaus-technik-kosten-foerderungen/
        1400 EUROS/sqm
        Comparison.             price/cost/value  !
http://www.micromedia.li/microhouse/microhouse-material-kosten.htm
19550 EUROS/39 sqm ~ 501 EUROS/sqm  living area material cost
https://m.all3dp.com/2/3d-printed-house-cost/
10150 USD/38,1 sqm ~ 266 USD/sqm. ~ 240 EUROS/sqm
Foundation
Walls
Floor& Roof
Wiring
Windows & doors
Exterior finishing
Interior finishing
                                                       < 200 EUROS/sqm
http://www.frame-house.eu/index.php/eng
                                                      < 150 EUROS/sqm
https://poly-care.de/index.php/de/    plastics-polymer bonded sand
or
http://www.earthbagbuilding.com/articles/eco-beam.htm.  sand in plastics-sack  http://ecobeamhomes.com/
https://www.calearth.org/intro-superadobe
                                                      +- 100 EUROS/sqm
https://m.all3dp.com/2/3d-printed-house-cost/  WINSUN ~ CONTOUR CRAFTING, the UCLA Prof. his ex-student
        http://contourcrafting.com/
                jovoto 300 US$ house (~ 50 USD/sqm) level          https://www.jovoto.com/projects/300house/landing
https://www.3dwasp.com/en/3d-printed-house-gaia/
900 EUROS/20 sqm = 45 EUROS/sqm
The GAIA  house with Insulation coating decrease in delta-phi 20°K  climate area the heat demand to 550 Wp/20 sqm,which by improved C.O.P. 10 heat pumps means 55 Wp electric  room air conditioning.
55 Wp electric ~ 100 Wp primary energy content  divided by 20 sqm living area =
NEARLY ZERO ENERGY BUILDING.   ENERGY STANDART
WASP "GAIA" with AC/warmwater heatsystem for < 100 EUROS/sqm  house construction < 150 EUROS/sqm with decentral= single room air changer with heat recuperation, kitchen and bath.
The above 1400 EUROS/sqm are for 1990 technical standart materials and equipment ,2019 anymore patent-exclusive = no-name home-depot ware,
licence-free produce-able in 3.world low salary countries for less than 300 EUROS/sqm
          as "PASSIVHOUSE EXCELLENZ CLASS"
Here some technical info from the 90', ISORAST = "PASSIVHOUSE-INSTITUTE Dr.W.F." -SPONSORSHIP
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fwww.hausbau-isorast.de%2Fdownload_isorast%2F
EUROPEAN CHALLENGE :
the lowest cost construction from the patent-/utility-model fee -free
https://passiv.de/   ~ Isorast demo-house from the 90'
In Australia : Isorast ~ ZEGO foam stone;
2019 over 80 companies all over the world are this foam stone producing
PASSIVEHOUSE-foam stone construction more expensive, same or cheaper than 3d foam cement printed houses. ?
"MASSWARE"-TARGET: every "PASSIVHOUSE"-KIT for less than 250 EUROS/sqm living area in the E. U.   !
sm0ky2
Using steel frame, and HDPS from companies like GeoFoam
A dwelling or commercial space can be constructed for 10%
of the cost of a modern structure.
And more than twice as durable.
Yes and we have also steel-foam and alufoam construction panels houses offer in this" compared 1/10 "
price level.
Next now the "Nearly Zero (Energy Building) " heating and cooling system :
Natural ( from conventional human view "extreme") NEGATIVE/SUB-ZERO 10° CELSIUS climate condition :and in this climate condition the humans their re-/action for well-being/health safety
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fm.spiegel.de%2Fwissenschaft%2Fnatur%2Fmount-everest-wetterstationen-messen-verblueffende-uv-werte-a-1301499.html
Ten degrees Celsius negative and walking in T-shirts ( if not...). ?!
(hot or cold ? Ultra-violett radiation warming effect( Solarium)  compared to ( hot or cold ? )infra-red radiation warming effect. ? Black/White light Boltzmann spectrum
Civil Court In/Sane well-being " Minimum-Temperature" for " inhouse living " decision. :
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fportal.uniplaces.com%2Fde%2Fwohnungstemperatur-gerichtsurteil-in-der-nacht-muessen-es-mindestens-18-grad-sein%2F
If the outer temperature is in the 0°Celsius state to heat up to 15°Celsius inside  or up to 20°Celsius is an 100% more energetic consume decision. !
5 thermic.degrees more are not calculatoric 25% : 0 to 15 compared 0 to 20 more
                                    but caloric 100% BTU more !
And 100% more energetic costs and the global climate temperature increasing action. !
So the new construction codes normations  and civil courts decisions demands :
                          SURPLUS ENERGY CONSUME, BY LAW !
                        WITHOUT SCIENTIFICAL FUNDAMENT  !
The use from such inventions and intentions
https://spectrum.ieee.org/energywise/energy/environment/wristify-thermoelectric-bracelet-would-reduce-energy-consumption
decreasing the room temperature( from average 20°C to 18°C or 16°C   and hold /increase body temperature
                   -by Court decision - illegal  : the room temperature decrease- inside house !
Or : http://www.rexresearch.com/cuinanoagwire/cuinanoag.html
      ...... ELEMINATE NEED OF INDOOR HEATING ( if allowed by CIVIL COURT DECISION)
IR-heater with direct far/near waves body and objects warming and room by well warm  18°Celsius POSITIVE heating :
           not sufficient inside house by " intelligent"  climate NEGATIVE changing "Court decision".
Who gives these judges scientifical consultance. ? Are they up to date.  ?
                Anti-Kyoto-Contract and Anti-Paris Contract decision
sm0ky2
We should recycle "global warming" to heat our homes.
If one problem is heating up our planet
Another is needing to heat our homes
Sound like a single solution could resolve both issues.
Instead of burning fuels for heat,
Just use heat pump for global cooling
