A-King 21 - build discussion /investigation
Started by ramset, July 15, 2019, 09:13:34 PM
a.king21
Quote from: partzman on July 18, 2019, 04:47:25 PM
Aking,
Referring to the Benitez patent 17,811, are you saying you and/or Rick have replicated either the first or second option of this patent and experienced OU?  If so, I'm sure you realize that the mercury-vapor converters or cathodic valves used an internal arc to operate so what did you use for rectifiers in your replications?
Pm
It was probably 7 years ago.  I used modern fast diodes. My replication was just a token to see if it worked. So I powered a neon bulb for several minutes under it's own power. The neon bulb kept going out and then coming back to life from nowhere.  You could not say the device was ou because the complicated Tesla switch was battery powered separately. However the concept worked ie the switching was getting energy from the ground.  I then moved on to the car battery setup using  2 in series and 2 in parallel and rotating them around. That worked fine till the Tesla switch failed and killed the batteries. I enclose a pic of the original Benitez "armature" if you could call it that.  I replicated the dotted line version. in 17.811. Even with my pretty poor set up the results were enough to convince me that he was genuine. On energetic, they have replicated Benitez but state it cannot compete with solar re price etc.
ramset
A king
your image made the page huge{ this bothers many readers do to scrolling back and forth to read.you should shrink it please.
and I know it drives certain Bears...well it makes them cranky .[you ever see a "Drop bear"??YEESH...]
Here I take a moment to Comment to AG who asked about Mark E
Mark E [ a member here who passed on...way too early in life
He worked to help persons all over the world advance the  understanding of super high frequency.. super high speed high power EE technologies ...he was noted world wide in his field for this benevolence [helping other EE's work thru problems ]
Member Poynt once described his work to me as a field of EE research  head and shoulders above normal EE.. studied by very few and understood by even fewer..
To say the least.. Tinsel was the type of experimenter Who could definitely appreciate this mans work and contributions here ....and really miss's him and his help.
To my Knowledge Mark E was at the very top in his field  ,and yes he is missed and we were very fortunate to have had him here.
He practiced brutal honesty and this made it hard for some to interact with him.[was hard for me too at times]
However
At the end of the day it should be a standard which can survive any scrutiny that will truly bring change.
Chet K  PS sorry if I post too much here ,just wanted to explain ,not trying to distract from the work here.
Thanks Grandma
a.king21
Just a note on the circuit I posted.  You have to get into the diode arrangement that Don Smith suggested to see the benefits.  The basic system will just circulate some of the energy back into the system.. i'll post a more complicated circuit when I hone my drawing skills on paint in a bit. It's when you get into the diode systems that you will see more  lethal voltages across the cap or caps.
seychelles
AlienGrey
Quote from: a.king21 on July 18, 2019, 01:12:30 PM
This will blow your transistors if not secure.
This looks a similar circuit why not try this it looks like the original but does not show earth connection.
