hammerFall gravity powered generator
Started by burnit0017, July 22, 2019, 09:59:18 AM
burnit0017
https://youtu.be/L0mgL8V8H1g
showing some improvement  ???  starting to fabricate the cap dump circuit for testing
conradelektro
You are building a very impressive machine!
If you are doing a full disclosure, you could film your machine from some distance in order to give your fans a complete overview.
Do you plan to run your machine (once it is finished) only from capacitors between output (from some dynamo) and input (to the drive motor)? This would be a good way to show over unity (in case it is a self runner) and would free you from all measuring problems. Some batteries during startup would be acceptable.
I am looking forward to your results.
Greetings, Conrad
burnit0017
burnit0017
I just realized I can remove one gear set and replace the transmission braking load with the load created when generating electricity. :)
kajunbee
You will come to realize many things in the end. Have fun and looking forward to your next update.
