Wireless energy transfer experiments ,Builders board
Started by ramset, September 18, 2019, 09:15:01 AM
stivep
Dear Stefan Chet and others..
______________________________________________________
In: https://overunity.com/18335/wireless-energy-transfer-experiments-builders-board/msg560166/#msg560166
I have shown  Electromagnetic wave  trapped in  Metal Air interface. https://www.nature.com/articles/s41598-020-57554-1
In article below there is  experiment from   end of 20tieth century   recorded also by Department of Defense
showing : Excitation of surface electromagnetic waves on water
A. K. Singh, C. A. Goben, M. Davarpanah, and J. L. Boone
https://vdocuments.mx/excitation-of-surface-electromagnetic-waves-on-water.html?page=3
Later on in 2013 Dr Corum  instead of  Mhz region used  kHz region frequencies to do the same in Seneca Lake
http://rexresearch.com/corumzenneck/texzon.pdf
In here  I gave exact accurate information about structure used  in kHz region experiment  1 day of work:
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg562296/#msg562296 -and even quite skeptical guys decided to write about it.
http://www.tfcbooks.com/articles/tws4.htm
It is more likely  that  Russian Kolbacict starts to experiment with it  before you do, because he is more  hungry for what you not in your comfort  I assume.
Sorry guys but my contribution to humanity  has its limits too.
Wesley
garrypm
Hi Wesley, When you have a few minutes to spare, would you be kind enough to check out this guy, Mtech Industries - YouTube
He is selling for $350 a kit. Making very bold claims, though I'm not seeing what all the hype is about.
Greatly appreciated,
Garry
stivep
 I have got OK from my partner to  publish l some details of  A to B energy transfer
that is related to Extraction of energy from  Schumann waveguide:
Part 1
Two points structure :
it can be any two points called A and B
Geometry:
- these points always belongs to the plane or line  and fallows curvature (e.g. of the earth)
Position
these points can be :
1- two ends of wire ( e.g: telephone wire or  Power line  or  Goubau line) https://en.wikipedia.org/wiki/Goubau_line )
2- two ends or two points  on the  ( aluminum/copper  foil) at   unlimited length.= conductor
3- two ends or two points  on the planet earth =  earth as a lossy conductor./and air making it  the interface
So at  point  A we have Tx and  at B we  have Rx
(Rx receiver Tx  transmitter.)_
Communication  or energy transfer is provided at specific frequency F
Losses of the signal  are present so you always  transmit more and receive  less or nothing at all.
These losses  are associated  with  number of factors:
- impedance  match between output of Tx  transmission line and the antenna  e.g  Goubau line or  (Tesla coil)
- efficiency of an antenna
- medium - medium will be explained later.
note: the same conditions apply to Rx too.
Dr Corum used  Tesla coil at A  as a Tx and also  Tesla coil at B  as Rx
Note: in the case of  Extraction of energy from  Schumann waveguide we deal  only with  Rx.
more in part 2
Wesley
stivep
Part 2
medium
Note: look at  green word medium in the previous comment.
medium is everything that is between point A and point B
If we have wire between these two points we are dealing with  impedance as signal is AC.
we have air between these two points.
Note: look at example #2 on the picture from above
If we have  air/earth interface  structure or Goubau line or foil
Note: look at example #1 or#3 on the picture from above
Quotein example #1- Space between these two "ends" or two points  on the planet earth =  earth as a lossy conductor./and air making it  the interface
- important is only that what is in that 2D interface between  Air and Earth (and quality of earth as a conductor)
  curvature of earth is not important as Electromagnetic wave in that interface is  fallowing  it.
Note: that  interface is simply flat waveguide and inverse square law doesn't apply to waveguides https://en.wikipedia.org/wiki/Inverse-square_law
This also applies to the  aluminum/coper  foil as conductive medium and Air as  dielectric - making it exactly the same interface.
Quote2- two ends or two points  on the  ( aluminum/copper  foil) at   unlimited length.= conductor
Note: Look at example #1 on the picture from above it.  it  shows earth and air  and imagine that you have foil instead of earth- width of that foil is  likely not that important
it could be  few cm as well.
NOTE: ( not what we  want)
Energy in form of electromagnetic wave  can also  travel between point
A and point B  as regular electromagnetic wave  but than  inverse  square law ,antennas, impedances and transmission lines applies
we  are excluding it  from this study and we are not interested with it  at all  - unless we need it as   a comparison.
Wesley
