Kromrey generator solved(?)
Started by pemox1, October 28, 2019, 09:42:39 AM
pemox1
Raymond Kromrey has signed up his patent in 1968.
Unfortunately I only can find his US-Patent: U.S.3,374,376
The explanation in this patent is a bit confusing, but the principle is (I think) clear:
A PM (permanent magnet) is attracted by an iron, which is wrapped with a coil and induces an electric voltage in this coil.
The best part:   The electric curcuit is OPEN, so there is no current. Because there's no current there can not arise a magnetic field in the coil !
That's why PM and iron are attracting each other until they're facing each other.
But exactly when they're facing each other, the electric circuit will be closed so that an electric current occurs which creates a magnetic fieldi n the coil and the iron.This magnetic field now repells the PM - and PM and iron are drifting apart.
It's like Luling argues:  the magnetic field will be "neutralised"!
pemox1
The principle:
And my first modified generator
sm0ky2
Anti-Lenz
That seems like an easy build
have to address the switching issues
maybe as simple as a reed switch in the right place?
MasterPlaster
I hope this helps:
www.rexresearch.com/infolios/kromrey.pdf
skywatcher
As soon as the switch is closed, there will be a breaking effect on the rotor, like in every other generator.
