Kromrey generator solved(?)
Started by pemox1, October 28, 2019, 09:42:39 AM
bistander
Quote from: pemox1 on January 02, 2020, 10:12:38 AM
The principle:
And my first modified generator
Hi pemox1,
In panel #3, showing the magnet aligned with the center of the coil, the generated voltage in the coil will be zero.
In panel #4, showing the magnet departing from the coil center and the switch closed, the resulting current will produce an mmf distorting the field resulting in a force resisting the separation of the magnet from the coil center.
Regards,
bi
nix85
 It seems to me he is reducing lenz but is using extremely confused and flawed theory in his patent to explain it.
sm0ky2
2 months ago I would have ignored this completely.
But an electric machine I invented displays similar
properties in the right configuration.
The exact opposite of the electromagnetic drag
we experience with a normal motor/generator.
And by that I mean an electromagnetic force in the
direction of rotation in agreement with the negative portion
of Maxwell's equations.
Probably a result of my education, I had never considered this to
be a 'real value' solution. But it exists, exactly as Maxwell told us.
It is a matter of timing and location of pickups.
In one configuration, the drag is against rotation.
In the other, the negative drag pushes the rotation along.
In between us a theoretical point of "no drag".
pemox1
I'm very interested in your project. Even in your reed-switch. Can you please show me a type that can switch 12 ampere?
sm0ky2
After giving this some though
I think this approach will work better.
Take a look at this optical sensor array
at the beginning
https://youtu.be/BPSsXKp_hWw
