My Ambient Powered AC Amplifier And Oscillator Square Wave Generator
Started by joellagace, November 24, 2019, 07:53:34 PM
joellagace
Good day all! With some of my own experiments based on Tesla's Radiant Energy Devices, I came up with this!
This circuit uses 2n2222a transistors configured as negative resistors. A primary full wave rectifier pulls in various  Ambient energy spikes. Such as RF, Magnetic and even Earth Currents. It is very important to use large capacitor antenna, Such as a large metal sphere up as high as you can in the air. The antenna capacitor must NOT be earth grounded!! Use Coax as an electret capacitor feed line. Short out the coax at the top that connects to the capacitor antenna. The electret properties of the coax will greatly enhance the effects of collecting energy. AC ground Must be a REAL earth ground such as a cold water pipe. This circuit will fail to work without a proper ground. At the proper location. The first rectifier in this circuit can get peaks of 12 volts without connecting to a charging capacitor. This circuit has enough self  capacitive properties that after a few moments a DC bias is formed and negative resistance AC amplifier properties kick in within the rectifier sections. Transistors also have some capacitor properties along side with the breadboard.  Capacitor one is charged up to the trigger voltage it takes to turn on switching transistor 2n2222a, This pulses the DC output voltage of rectifier 2 into L1 coil. The secondary  side gets a pulsed DC square wave output. For what ever usage you may have. It is 100% powered by the Ambient!!
If you can't get an antenna up, Stashing a tangle of 50 feet or more of electret coax, If you have a sort of commercial oven. Google up how to enhance the electret properties of a coax. It is very worthwhile for a project like this! Then simply tangle that spaghetti of coax in a bunch some place inside or outside and it will work not bad as a power sucking antenna.
Tesla had a thing about using the earth energies to power his various switches, This helped him along with other projects and usages, So With that said I wonder what next could be done with this? Step the voltage up or down as needed, Pulse charge batteries and capacitors at varying voltages? Or maybe just like Tesla did, Use it as a free energy operated control switch for what ever project that may require such a device?
Here is a Youtube video of the device I built in action showing the square wave generation on an oscilloscope 100% Ambient Powered!
https://youtu.be/vO_2YmtAmU0
Now I just wonder what would the next step be ? What could I try next? Any ideas to make the circuit work better? What are your thoughts!
carbon sugar
Hello this circuit is good for my POE vortex coil, that low frequency would be very useful with the toroidal coil, I use the POE coil and only need a low frequency AC pulse, the coil converts that pulse into high frequency, it would be great for what I need, my idea of ​​the device comes by there, it is the energy lowered as a radio station, tesla style, moray, I want to build a circuit like yours, so I use it with my coil, I have been looking for it for a while, that pulse could be amplified with vacuum valves, they can be amplified put 3 - 6-9 - volts and take it to hundreds of volts with those valves
joellagace
Well I'm still working on this and taking it to the next step. I plan to step up these pulses or collect enough energy to be able to drive Spark. There are various almost endless methods at this point I need to explore and choose. To produce this effect. Next I'm working on the coil assembly.
L1 and L2 no problem, But Low impedance L3 was such a bitch to bend and keep in place esp if you suck at building things with your hands like I am haha! Needless to say I figured it out, It may look ugly but it worked out! Now next step is to wire this up to one of my many circuits that use ambient and negative resistance amplification and earth telluric currents. That 12 volts "free Energy" square wave, I can use that to power a step up, like a fly back circuit to get a tiny 1kv operational spark gap. Or maybe even just via step up transformer if I can find optimal frequency tuning. That produces my 1kv high voltage spark and let the coil do the rest.
The coil also feeds a special or very plain motor that can handle high frequency pulsing currents and spinning shaft (optional gravity flywheel attached, Not sure if its even needed at this point) connected to that of a regular generator motor, and you get the idea of the rest. Every one seems to not be that impressed with my various  prototypes that only run LEDs and tiny lights, I wanted to just prove points of concepts, I guess that's boring in today's world so I'm going bigger, This one I'm building now should power, tools fans heaters etc,, If I can get away with the 1kw or so of output im expecting with a generator it could drive.
I'm thinking of using a coax instead of a center core rod as the coax dialectic and capacitance might do some enhancing effects with high frequency pulsing. Yep the core is live, kind of like how it is with a MOT :) I need to build a few different variations of this coil and experiment with some ideas til I find the optimal setup. Its not a Tesla coil! but its based on many of his foundation ideas.
On how I think this works in part? This coil also acts as an ambient "AC" amplifier. How could this work you may ask, It is the effect of negative resistance device acting as an AC current amplifier. But where do you get the negative resistance? Easy! Its the spark gap. Many seem to forget apart from acting as an efficient interrupt. The high voltage spark gap also acts as a negative resistance device. But a negative resistance device needs to have some DC bias voltage to be able to operate as an AC amplifier. That is also easy. This coil provides it's own source of self bias "DC" or what appears to work as DC at a specific very high frequency as Tesla observed with a well tuned coil system. But only at high frequencies is this "Fake" DC  apparent. Tesla wanted to "DC" power his Xray death ray tube at the top of his Giant Tesla coil via this method! So why not use some of his ideas in part!
The next important stage is that this coil grounds at two separate coils within. And the two earth grounds need to be well spaced apart. What does this do? Well at high frequency AC, that is More seen like Very Low Frequency or VLF to the ham radio operator then AC hehe! Acts as a big underground loop. The VLF folks use this method to build "Virtual huge underground loop antennas for VLF listening hobbies. What this does in my case as Tesla said, We must keep the loop closed and this does just that, Also taps into the earth telluric currents, and taps into the huge negative energy potential of ground where this "ground" doesn't really act as ground no more in this circuit but a huge infinite reservoir of energy. That can supply at high frequency pulses current to an inductive load (We must not break the loop) like that motor i want to spin and drive another generator for regular compatible use energy that powers our regular house hold stuff. Well thats my hypothesis/theory/ etc anyways on how it works.
Hope I get somewhere with it all on the larger scale! Wish me luck! I will keep you posted from time to time. But I post more often on my youtube! If anyone has any suggestions of course I'd love to hear from you!
Toolofcortex
Pay attention to the recent gerson paiva replication, and the iraq replication.
good luck
joellagace
For sure, Will do, anything can help, everyone has their own version of saying how this all works, It gets confusing, But all info is needed :)
Right now im wondering if I should take the output from the generator it would spin and charge up a super capacitor bank emulating for example a 12 volt DC battery pack. This would offer much less charging resistance then rechargeable batteries and could take a beating much better then batteries when it comes to charging and rapid discharging. People have destroyed batteries trying to charge up similar circuits and coil i'm experimenting with, Maybe replacing with super capacitors is the answer and use that stored energy to power your everyday things, 60 Hertz AC inverter etc.. and also feed power to the spark gap circuit that drives the coil! That would be a method of keeping the whole device running on its "own"  and producing more at the generator output once it has started up for a few moments.
