My Ambient Powered AC Amplifier And Oscillator Square Wave Generator
Started by joellagace, November 24, 2019, 07:53:34 PM
carbon sugar
Fabulous Joel, can you change the transistors for radio valves that make that function? what you need is negative, radiant, non-magnetic resistance, take out the magnetism, use dialectic, go back to the old school, you know about it, amateur radio, valves that are negative resistance, the frequency rises, and a spark gap too connect the earth on one side and on the other side is the radiant negative, that high frequency, is a disruption, and that in a tesla coil, is scalar wave, pure harmonic to keep the frequency stable, the scalar wave is everything, it is longitudinal, the magnetic and dielectric together, that coil is going better with that, but something more terrifying, I'm going to copy it and test, I want to use old school radio, big hug, tremendous work, remember, negative resistance, that pulse pulls energy , positive resistance sucks energy
joellagace
I am thinking of going back to the driver circuit and make it better, I was going to try with bigger transistors first. They can also act as negative resistance and like someone already mention on here, perhaps they could absorb more energy as well!
I probably will try the vacuum tube rectifier as well at some point, I just need to find more parts for the sake of experiment, But I am trying to break away from the tubes. Perhaps possible perhaps  not. I'm still experimenting.
joellagace
And if you want to build the Moray generator, How would we enhance the valves with radioactive coated components inside today without getting into any kind of serious issues? I sure don't have access to that kind of a shop or lab.
But could we temporary radiate from an external source next/enclosed/shielded to the valves and produce the desired effect with normal valves? I don't think so, But I don't know. Would be cool if we could. Then something like the radiation of a home made fusion like reactor or something.? But I guess this is going a little off topic into fantasy land.
carbon sugar
If the moray is good, but there is still a lot of distance, I read about the active radio minerals, I don't know to what extent the minerals are true, a lot of misinformation, I say it because here in my country at that time there was also a geophysicist that he invented a weather machine, which was later removed and made the haarp, used in his machine, amateur radio style, henry moray style, baigorri velar is called, look for his things if you want, he is Argentine, he used active radio minerals, Lead is an active radio for example, carbide, there are several, I will pass the names of the minerals I used, name them in a video, the other is that today's transistors are very rigid, not flexible like valves, there are several things that raise the frequency a lot using low voltage, you know much more than me about that, I will follow your steps, try some change to add to the experiment, and the best longitudinal waves, scalar waves remember, tesla just use the electromagnetism, the Electrostatics to produce scalar waves, 180 degree phase angles, a better air antenna and a better ground antenna, your ground connection could be better, more potential difference in those two points and maybe some bucking coil with some core of ferrite powder or iron powder, remember the spark-gap, some high voltage variable capacitor (radio style), you know how to see it with better eyes, and put together something new, I'm still attentive to what you do and I'm going to experiment I'll start with your circuit, hug
joellagace
But i'm still not 100% sure what the valve does in line with the inductive load area. Other then create some X-rays and bunch of strong RF noise splatter. I guess what i'm doing now is just trying to use this energy to cause random effects until I can figure out how to actually better utilize it.  I'm still somewhat fascinated at what its doing now (the Valve) even if it may not have anymore practical application for my goals here. Still some experimentation with valves to come! But I really want to break away from the old tubes if we can!
This is how the valve looks like in the dark. I did not notice this at first in the light.  My cam has a hard time but it has a blue glow and you see these glowing stings crossing the inside of the tube, It almost looks like the inside of a plasma ball running :)
