"Quantum Receiver".
Started by synchro1, December 06, 2019, 06:08:06 AM
synchro1
Quote from: Toolofcortex on December 10, 2019, 01:47:13 PM
You know what? You are pretty smart and good at this.
Keep it up.
Maybe some crazy autist will understand you and build the device you imagine.
Do you guys know what an "Avramenko Plug" is? An LED with two reversed diodes connected together and to the ends of the LED. Do you know what it's good for and how it works?
Here's a tunable receiver that can receive the 13.56 frequency:
https://www.youtube.com/watch?v=fOkkF4pr23s
An L-3 coil resonating at 13.56 Mhz from a Crystal oscillation (Signal Generator) no power, will illuminate an LED wirelessly with this simple kind of LED diode antenna. Just holding the plug close to an oscillating crystal at 13.56 Mhz should enough by itself to generate a current in the LED. A slow guy could handle that.
synchro1
synchro1
Placing the LED where the spark gap is above, would make, 3 diodes end to end in a loop from Avramenko's patent; Stiffler's diode loop collects the same static energy. Without a coil or magnet, modulating this loop will work fine too.
Modulating the static field in this loop opens a spillway for Quantum Power from the Infinity of Space.
Toolofcortex
Ok smarty pants.
What is your opinion on the Steven Marks TPU?
synchro1
Quote from: Toolofcortex on December 10, 2019, 04:52:16 PM
Ok smarty pants.
I think there's something to it; He worked with amps and apparently was log jammed by an overheating problem. The Capacitor coil of Hendershot and Akula look more like capacitive resonators..
