Thanks to ALL for your help!!
Alternator = sm0ky2
Started by massive, December 23, 2019, 02:50:06 PM
sm0ky2
Meyers was working on an extension of Victor Schauberger's work.
Start there, at the beginning and you will see what/why Stan was doing that.
Frankly, the open-air combustion of H2 + O is so thermodynamically unbalanced from
it's production that to call it anything less than infinite energy in a clean renewable cycle
is just giving it another name..... it doesn't really how you made the stuff, it will melt your
piston heads off the engine if you run it for too long.
To actually use the stuff we need to bore our cylinders larger
use titanium piston heads and expand the thickness of the block
add more coolant paths, etc...
It's not complicated science, set the engine aside and just use it as a torch.
You can boil water and time the event.
Melt almost anything.....
Or heat a thermal converter
or thermal storage unit.
You could even make steam and run a large generator.
They compare electrolysis to Fuel Cells to meet the 2nd law.
Not to combustion.
They shut down Brown, saying his claims were bogus... "Brown's Gas, my ass!"
Do the math on the combustion and see the numbers for yourselves.
Don't trust scientists paid by the oil cartels.
Hydrogen releases all of its energy almost in an instant.
Much much faster explosions than gasoline.
When the O2 is greater than a stoichiometric mixture, the temperature is so high
that the oxygen itself acts as a fuel, further increasing the heat.
I think the best H2 car would be ran by a sterling engine and a torch in a burn chamber.
Or be powered by a closed-cycle steam engine in a similar manner.
Direct conversion of the heat, rather than the thermal expansion force.
Alternatively, similar efficiency could be achieved by turning the ICE engine block into a TEG
to recycle the heat back into the electrolysis process.
sm0ky2
I once engineered a TEG radiator.
Perhaps that could have applications in H2 ICE cars
citfta
Hi Smoky2,
You seem to be a little confused about why field coils are used in an automotive alternator instead of permanent magnets.  If permanent magnets were used to excite the alternator the output voltage would be directly related to the speed of the alternator.  By regulating the current through the exciting coils of the alternator the alternator is able to produce near constant voltage under varying loads and engine speeds.  A necessary requirement for automotive use of an alternator.
You are correct that permanent magnets are more efficient.  That is why they are used extensively in industrial DC motors and even in small hobby motors used in RC airplanes and RC cars.
And what is a TEG radiator please?  I am not familiar with that term.
Carroll
sm0ky2
Thnx Carroll
I guess I never thought about that situation with the belt speed
and whatnot...
Makes sense...
TEG radiator was essentially a series of Seebeck generators
integrated into the water cooling system, such that a portion
of the heat is converted directly into electricity to power onboard systems.
It was designed for utility purpose in the shipping and commercial transport industries.
But also could have applications in passenger vehicles to improve efficiency.
In particular, a water fueled vehicle could use the electricity for fuel production.
Toolofcortex
You are talking way too much gibberish, can you turn the nonsense bot off?
In the current state of art, There is no such thing as a self looping hydrogen engine that recharges its batteries and provides power.
For that, you need to run the engine at high speed, not at idle.
There is also the problem of thermal runoff and steam generation due to the cell running hot after time.
If the cell doesnt run hot and all the amperage restricted in the way others like ed mitchell shows (minuscule bubbles), then not much electrolysis is hapening thus not much gas. Theres about 100 people on ionizationx that produced the VIC and produced bubbles.
It simply is banal electrolysis, the amount of gas is minuscule so of course it stays cold, or should we say absorbs heat more slowly and dissipates it.
All these problems are well known by science, there are no greener pastures available by making electrolysis and hooking up to the engine and somehow completing the loop with water only, not with current state of art.
Now in the Stephen Meyers MLS hydroxyl paper, a novel way of going about electrolysis about is described and a schematic is given.
Now this man, Stephen Meyers, is a subject matter expert, and has seen all that could be seen and all that could be known. Whatever he says, goes, and if it doesnt go then consider it a dud and phony.
Anything anybody else said, Ed Mitchell, Smoky2, is automatic garbage from non subject-matter expert, and goes straight to the trash. Also, your way of presenting data or theories is not even worthy of mention or review.
