Intercalated graphite carries a resting voltage without giving a charge.
Started by Jimboot, December 24, 2019, 05:29:23 PM
sm0ky2
Try an analog meter
some of those dmm's can send V in reverse
because of the way the internal resistance circuits are designed.
The voltage climbing when you connect the meter may be a clue.
sm0ky2
Nice work making it conductive.
In theory, it is possible for Cl Ions to have been trapped
inside the carbon lattice
however it is a higher probability that some iron was not
able to fully oxidize, and therefore would also be trapped
inside the carbon structure.
This will of course depend on the cell structure of your carbon source
and how it is contained during the thermal processing.
I have not yet had that much success, but was on a similar path about a year ago.
I got distracted into reactive nanocarbons because they act like they're alive.
sm0ky2
Acetates were a little easier for me to work with
my goal was entrapping ionic metallic acetates in the lattice.
Equally as hazardous but lower working temps.
in a hot liquid crystallization process, it is possible to
bond a metallic salt directly to the carbon while it is forming
allowing the growth of a complex crystalline interface
Most of my experiments failed because I was using the wrong
type of crystal and the carbon wasn't able to out gas properly
Jimboot
Quote from: kajunbee on December 25, 2019, 08:17:09 AM
If you have your meter connected between anode and cathode you are seeing galvanic voltage. You won't be able to discharge it like a capacitor. I am also working on a rechargeable aluminum ion battery. I've only been at it a few weeks so I've still much to learn. Looking forward to seeing your further progress. Ps: The oxide layer that forms on aluminum is a killer. Saltwater will not readily strip it away.
there is no corrosion. There is no chemical reaction, the cell is dry
kajunbee
I saturated a paper towel in saltwater and then dried it in microwave. I placed it between a 2"x2" piece of copper and aluminum. The voltage I measured was near about the same as with wet separator. As a control I used a dry towel that had not been soaked in saltwater and still measured a voltage. Now for the stick in the spokes. I removed the copper and touched one probe to aluminum and the other to wet separator and also measured voltage. Lay the probe tip on its side so as not to penetrate the towel. The readings varied between.5 volts and .7 volts on all test. Maybe you can try this to see if you get similar results. i have suspicions of what's going on, but can't be certain.
