e-drive platform
Started by lancaIV, December 29, 2019, 09:47:18 AM
ramset
Lanca
http://www.evalbum.com/
Very nice indeed
This type of retrofit will be the future when
One of these members here who writes "FE is
Everywhere in plain site"
Actually gives us one "Real" open source example !!
Very nice website
Thank you
With gratitude
Chet K
Thanks Grandma
Hmm," retrofit" or "hybrid"-conversion !?
New cars ,small but so called " compact car class" we can calculate with 15.-20.000 Euros market prices !
DE4332378 Kurt Fritzsche or DE10103108 Peter Rust hybrid conversion concept
When an ic-engine car is availed with 30 GHG units per 100 Km and an electric motor ,battery sourced,car with 1,25 GHG units per 100 Km :
pure ic engine car to
hybrid conversion : 50% less consume
Arakelian fuel ( hydrogenized hydro-carbon fuel 8 :1 ratio )
we get
30 /2 /8 = 1,875 GHG units per 100 Km
Now,to decrease the GHG units we have as options :
CO2-car exhaust filter system
Optimized electric generator : less 40% kinetic input in comparison conventonial electric generator by same output
engine with 80% (Uni Michigan,Multi Disc) up to 90% (CDA :gun engine) conversion efficiency
Internal combustion hybrid cars can be as clean or cleaner than electric battery cars !
30 /2 hybrid conversion /8 hydro fuel  x 0,6 generator
~ 1,125 GHG ( without CO2 filter) converted hybrid car /1,25 GHG new electric battery car
Kurt Fritzsche 3 liter gasoline /100 Km x 0,5 ( instead 40% efficiency 80% efficiency engine ) x 0,6 generator =
           0,25 Kg hydrogen per 100 Km ( 1 Kg ~ 37,58 KWh )
with in comparison 100% output  conventional electric drive optimized comparing 200% output electric drive
          0,125 Kg hydrogen per 100 Km
judbarovski.livejournal.com    1 Kg H2 for 0,1 US$ production costs
                                                       factor 100 or 10 000 %
www.edmunds.com                  1 Kg H2 for 10 US$ at fueling station
Assumimg the gas station selling price related 1 US$/Kg hydrogen production costs actually,the selling price can decrease up to 90% to the 1 US$/Kg gas station end price level !
The 2015 R&D 'Automotive Onboard Hydrogen Storage'- targets :
5 Kg hydrogen in 55,6 Kg storage weight and 62 lt. volume by 333 US$ production costs and 2,5 min refueling time
5 Kg storage / 0,125 Kg per 100 Km consume ~ 4000 Kilometers drive range
5 Kg storage /  0,25 Kg   per 100 Km consume ~ 2000 Kilometers drive range
5 Kg storage /   0,5  Kg   per 100 Km consume ~ 1000 Kilometers drive range
Attention : liter and/or Kg consume and the specific energy per liter and/or Kg
      1 gallone gasoline/Benzin ~  3,758 liter gasoline ~ 1 Kg (compressed) hydrogen ~ 37,58 KWh
This means : the Kurt Fritzsche ic-engine ( conventional 40% efficiency )  now instead  gasoline hydrogen combusting and a Akiro Hara generator couple gives by 5 Kg Hydrogen storage up to 1000 Kilometers drive range
We have in option : David Yurth generator coil coating
                                   Ferreira electric drive
                                   Porquer differential
We have the clean environment technology ! 3rd world production price : new hybrid cars ≤ 4000 Euros
4000 Euros is much ! TATA NANO ,for the India MIDDLE class concipated : +- 1900 Euros !
In the 3rd world 4000 €  ' upper middle class '  investment level !
~ european private household 30.-40.000 Euros equivalent !
https://en.wikipedia.org/wiki/Tata_Nano
Announced as the most affordable production car in the world, Tata aimed for a price of one lakh rupees, or ₹100,000, which was approximately $2,000 US at the time.
Curb weight600–635 kg (1,323–1,400 lb)
$2000/625 Kg =                 circa $3,2/Kg  industrial controlled mass production selling price , not production costs !
68 Kg x $3,2/Kg =          $217,6        linear mass production calculation ::) x factor 10 :
                                                  $2500 selling price for electrocopter possible !
68 Kg = 150 lbs
https://contest.techbriefs.com/2012/entries/transportation/2689
The ElectraCopter is a single-seat ultralight electric helicopter. At 150 lbs empty with batteries, it will fit into the 254 lb limit USA ultralight category for unlicensed aircraft. It can be potentially used in other categories and in other countries, depending on regulations and design criteria.
• The helicopter works by means of a solid state battery, powering a 20 kW electric motor acting as motive power (and generator) with fly by wire electronic controls and servo flap blade actuation. Yaw is governed by piezo gyro and rotor speed control by microprocessor. Triple redundant military spec computer control chips for safety. Tail rotor is a separate, directly coupled motor to a fenestron protected tail blade assembly. A ballistic chute is an option. Instrumentation is a HUD in the helmet – no console.
A. which RPMs ?
Siemens 5 KW/Kg edrive for flying objects ,similar Helmut Schiller motors/generators
https://press.siemens.com/global/de/pressemitteilung/siemens-entwickelt-weltrekord-elektromotor-fuer-luftfahrzeuge
http://www.schillergy.com/pdf/schiller-energy.pdf
or :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20001020&CC=FR&NR=2792258A1&KC=A1#
or: https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=2&ND=3&adjacent=true&locale=en_EP&FT=D&date=20091130&CC=PT&NR=104078A&KC=A#
by 18 000 RPMs for long life coated by
https://www.internano.org/node/782https://www.indiegogo.com/projects/quantumcoat-more-hp-mpg-stops-engine-wear--2#/
https://www.energy.gov/science/bes/articles/nanodiamonds-slip-n-slidehttps://www.materialstoday.com/carbon/news/diamond-puts-a-new-shine-on-frictionfree-graphene/
https://www.materialstoday.com/nanomaterials/news/nanodiamonds-2d-materials-dry-lubricant/https://www.anl.gov/article/nanodiamonds-are-forever
The potential applications include bearings and mechanical pump seals in dry applications as well as in wind turbines. The technology could also be used in the computer industry; specifically, in magnetic disc drives.
https://www.piprocessinstrumentation.com/bearings-seals/article/21149510/exploring-the-possibility-of-limitless-bearing-wear
Further studies build on this research. In addition to being low shear and highly protective, the application of graphene in bearings prevents oxidation of the steel surfaces due to its relative lack of permeability to liquids and gases. Research conducted by the U.S. Department of Energy's Argonne National Laboratory4 shows that the small number of layers in graphene reduces not only friction in steel seven times more, but also wear-and-tear 10,000 times more, reducing tribo-corrosion.
https://www.nanodiamond.co.il/image.ashx?i=29404.pdf&fn=Horizon_2020_Wind_Power.pdfIncrease in service [/font]life [/font]by [/font]the factor of [/font]3[/font](high [/font]wear resistance  of [/font]tools) [/font]
alternatively : bufo.ru surface treatment
https://web.archive.org/web/20040803031518/http://bufo.ru/indexeng.htm
But :  https://cordis.europa.eu/project/id/315239/reporting
Improve the lifetime of the engine parts:
There is no indication of significantly improved lifetime of the different engine parts tested.
Beside engines improvement : https://www.coolingpost.com/features/nanotechnology-to-boost-hvac-efficiency/
Faster production :   https://www.emerald.com/insight/content/doi/10.1108/aeat.2002.12774cab.008/full/html
the electrocopter also to see as unmanned transporter alternative to transporter-drones
Actually alibaba DC permanent magnet motor Kg average price : 15 US$
Siemens or Schiller or Ferreira 4 Kg the 20 KW electric motor a $50/Kg = 200 US$ , 7 Kg a 50 US$ = 350 US$
When Schiller 1 KW nominal 3000 RPM weights 2 Kg = 40 Kg 20 KW ,6000 RPM = 20 Kg ,12000 RPM = 10 Kg ,18 000 RPM = 7 Kg
                                               alibaba  market price comparison
Net weight:  25.2 kg    price  1 - 49 Sets $425.00           = less than 20 US$/Kg
https://www.alibaba.com/product-detail/2kw-3kw-5kw-6kw-20kw-25_60760879706.html?spm=a2700.7724857.0.0.cca042346yKxSS
Weight: 820g               price  $439.90 - $689.90  / Set |                                1 Set/Sets (Min. Order) = more than 500 US$/Kg
https://www.alibaba.com/product-detail/T-motor-New-high-torque-1kw_1600105014442.html?spm=a2700.7724857.0.0.1cbc4234j3ABOi
 :o  ,real(-ly?)!
https://portuguese.alibaba.com/product-detail/china-factory-direct-supply-new-cheapest-4-wheel-electric-car-ev-vehicle-1600191928203.html?spm=a2700.galleryofferlist.normal_offer.d_image.552f2c30VJT71H
2-29     units  3 300,00 US$     near   3 US$/Kg car
30-499 units  2 400,00 US$      near   2 US$/Kg car
>500   units   1200,00 US$      near   1 US$/Kg car
Curb Weight : 1176 Kg
        compared
TATA NANO  https://en.wikipedia.org/wiki/Tata_Nano
   curb weight 600-635 Kg and with a launch price of one lakh rupees or US$2500 in 10 January 2008
                                                     =    4 US$/Kg (2008)
        car-share/-rent
1000 units "chinese car" group-buying : 1822 US$ per unit                   all + transport costs/national safety standarts attention
2000 units                                         : 1511 US$ per unit
3000 units                                         : 1407 US$ per unit
                                                      for example CN to Portugal
a given offer about 2 units minimum buy : (2x 3300 US$ =) 6600 US$ +  :-X  9000 US$ transport costs = 15600 US$ for 2
        7800 US$ each
https://en.wikipedia.org/wiki/Tesla_Model_3           Curb weight   1,611 kg - 1,847 kg
without "Title-Rank-Name Marketing" ,only material transforming, as new units near 2000 Euros value vehicles
as same Toyoda,VW,BMW,Mercedes-Benz,Porsche,Ferrari   and all other "transformed material on 3/4-wheels" companies.
2000  Euros per unit worth
x Factor 6 ( commercial marketing margin,patent,concession) price 12 000 Euros
x Factor 2,5-3 ( Max. based local employies earnings/Max. local product price credit- user ) price
        30.000 - 36.000 Euros per unit
Car finance : up to 36.000 Euros price by 2000 Euros industrial capital= substance,material in Kg  worth
                       Over 90% capital- uncovered,Rating: Triple E ,junk bonds level
                       New car trend : short user-ship ,only daies,weeks,months contract
Citroen Ami lease-Abonnement : 20 Euros per month ( 6000 Euros buy )
                                                  City-Micro-/Kei-(JP) cars
