All Permanent Magnet Motor
Started by magnetman12003, March 28, 2020, 03:43:49 PM
synchro1
The steel carriage bolt would be attracted to the ring magnets and kill any rotation! Turned upside down, the rings would spin longer with the carriage bolts removed from the underside then if attached.
magnetman12003
Quote from: synchro1 on May 17, 2020, 03:18:45 PM
I put the steel carriage bolt there to show the 2 ceramic wheels under  the wood disk while I took the picture.  It means nothing here except to separate???
synchro1
Quote from: magnetman12003 on May 17, 2020, 03:29:27 PM
They're still gonna stick.
magnetman12003
Quote from: synchro1 on May 17, 2020, 03:35:24 PM
That's incorrect. I just tried ( 2 ) six inch carriage bolts without weights on them on my setup without the tumblers just using my fingers and my setup turns quickly.  Soon as I get my tumblers mounted I will be showing a hand free video.  There is no sticky spot or wobble just a straight counter clockwise turn from the get go.  You can produce a clockwise turn by reversing  the drawn image  Shown on page 10
conradelektro
Quote from: magnetman12003 on May 17, 2020, 03:01:11 PM
A Gibraltar TALL ( There is short ones)  flanged base cymbal sleeve 8mm is what pivots the 1/4 inch thick wood base I have
The mounted wood setup is under of a old 45 black record.  Cymbal  sleeve Found on EBay.
The 50x 25x 10mm  (4 each) cuboid magnets are set at 45 degree angles by
45 degree brackets silver furniture angle joint corner support. Both Found on EBay.
I am going to enclose a photo of the two all ceramic wheels separating the wood setup disk from the
Large ceramic ring magnet under it.
Tom
Thank you Tom for the explanations, the photos and the disclosure. Everybody who wants to experiment is able to do that now. And I am sure You will show us your invention once you have the tumblers. I also experience huge shipping delays in this world wide virus crisis.
I hope critics will realise that a full disclosure of ideas is rare. Please applaud Tom and stop giving him a hard time. He has come forward.
Greetings, Conrad
