All Permanent Magnet Motor
Started by magnetman12003, March 28, 2020, 03:43:49 PM
magnetman12003
There is no hidden pancake coil or Tesla coil period!!! If you will construct my setup as shown you will be amazed as I was that it works so long as the threaded steel bolt actually touches the 45 degree block magnet at a angle.  That angle can be set using the top of a tumbler so one can work it finger free.  That's my next step.
Tom
magnetman12003
Quote from: magnetman12003 on May 19, 2020, 03:19:05 PM
Tom
There is no reason the large ring magnet now has to be under the free turning  disk with four 45 degree magnets mounted on its surface. I only included it so the disk won't wobble when weighted down.
As long as the threaded steel WEIGHTED rod makes contact with the magnet the disk will turn.
Think of that in simple terms.  You are stranding on a carpet with a slick oil spot under it. As long as you stand strait up you won't move.  The second your weight shifts at a angle the carpet will slide out from under you.
My setup is made that simple.
Tom
synchro1
any and all gravity direction is toward the center of the planet not sideways.
magnetman12003
Quote from: synchro1 on May 22, 2020, 10:08:37 AM
The 45 degree blocks are on the OUTSIDES of the 7 1/2 inch diameter spinning disk and that is not the center point of the setup.
End result is the disk spins with weight on the magnet blocks. I have tried this many times and it works every time as long as there is an angle between the threaded rod with weight on it and the rod touches the magnet block. 45 degree seems to work best so far.
Tom
Magluvin
If it is the additional weight that is the ticket, then does it have to be a bolt that is magnetic?
If it is a magnetic alteration that happens to the 'upper' pole to change its original path, then there must be many ways of doing just that in place of the bolts.
On of the issues with a mag motor setup like this is, and many dont realize this, is that the is just as much flux from the N side of the angles magnet as the is S pole flux thus no movement. But, if the bolts a redistributing the upper pole in a way that the top pole has less influence on rotation, then maybe the lower or say bottom angled pole has a chance at deflecting the rotor into rotation.  Im not fully convinced it will work as in most cases in physics like this, there is no release of downward pressure to allow continuous motion. But maybe it could be different with magnets..  What I mean by that is typically if magnets are in repulsion or attraction, the net result of any of these actions using moving parts would be the attraction would tend to move the magnets closer and repulsion would move them away. But here the differences would or should remain static, just like the big speaker magnet field, static.
Mags
