All Permanent Magnet Motor
Started by magnetman12003, March 28, 2020, 03:43:49 PM
ayeaye
Quote from: conradelektro on May 27, 2020, 07:47:53 AM
It is fine to go overboard with an idea and to hope for the impossible a bit too much. But you should tell us the truth. It was amusing, but the fun is over by now, it has become a drag.
It has. Not excluding any possibility, my estimation is this though. that Magnetman got some improvements, so it rotates more, with a lot of work, at that. Maybe he thought that his device is capable of continuous rotation, but maybe he didn't test it thoroughly.
Here though, one may throw away all that Magnetman could find, by abandoning his work as a continuously running device. I think he should provide more results of his work, and experiments that he did, to show the things that he really found. And these, if properly provided, can really be replicated.
This, all or nothing, is what makes the research impossible. People think about it like a treasure hunt, you either find treasure or you don't. But research is not a treasure hunt. It is a series of experiments and theoretical work, that gradually comes close to the solution.
People refuse to do that research, they replicate, and then it either starts to continuously rotate, or it doesn't. I said to test whether it rotates more easily in one direction, than in the other. People refuse to do even that, all or nothing. Don't they realize that approaching it like that is crazy.
Instead of trying to get it all at once, do research. Why no one replicates my experiment, i did an experiment, in another tread here, where i really measured gain of energy, and it was replicated and results confirmed. It is about 45 degree magnets that Magnetman used too. Yes it didn't overcome friction, but it is a gradual work to decrease friction, and increase energy gain. But no, all or nothing.
synchro1
Why are you stalling around? It would take five minutes for me to set those bolts up on an angle with the popsicle sticks and rubber bands. You sent to China for tumblers you couldn't get to work right?
You look like you're just procrastinating to a lot of people. Poor show!
conradelektro
Quote from: ayeaye on May 27, 2020, 09:47:13 AM
My problem:
If you want people to replicate your work you should tell them them truth. It is not helpful at all to claim that something turns by itself or is OU if it really is not.
Very often in this forum people tell tall stories (lies) about their non functioning devices. Some are deluded or handicapped, but many simply lie.
It is fine to tell that something is a so far inconclusive experiment, but please do not make unsubstantiated claims, do not embellish your contraptions. You will look silly or you seem to be a crook.
Greetings, Conrad
magnetman12003
Quote from: conradelektro on May 27, 2020, 12:30:53 PM
My problem:
Greetings, Conrad
I really found that by using the 45 degree magnet angle  I got it to work somehow at first
but later try as I might it did not work.  It seems by working overhead as one does using the fingers
is the way to go.  If you are following me without doing anything at all so be it.  If you are experimenting on your own you will find that the overhead sling setup I last described is working for me. I plan to make a video to show it in action within a weeks time. I have to find out how long it will operate first before I get really excited.
I am only using two threaded steel bolts with weights on them presently.
Four will be used later for more power.
magnetman12003
Quote from: magnetman12003 on May 27, 2020, 03:28:42 PM
After thinking it over I plan to show the working motor only after I patent it.
I already gave out enough information about it if someone decides to use the SLING METHOD of making it. It's not as simple as it looks to be as anyone attempting to replicate it will find out.
But you will see the light after you play with it a while.
