All Permanent Magnet Motor
Started by magnetman12003, March 28, 2020, 03:43:49 PM
Magwood
Hi guys, I have been following this topic online for years, facinating stuff. This looks promising magnetman, well done. I'd love to have time to play around more with this one day. Will get some things together. I have a small workshop and cnc router so will make some parts. I was wondering if the rods could be rotating? Picture two donuts squashed under weight as they are stacked together. The gravity is constantly pushing the flux lines up rolling into the centre of the donuts. Toroidal flux lines. So the rod is like a surfer on an endless wave. Rolling over the flux line surface endlessly trying to fall into the centre and the 45 degree causes sideways drag? I don't know, just thinking out loud. Maybe it has something to do with Poloidal–toroidal decomposition?
https://en.m.wikipedia.org/wiki/Poloidal%E2%80%93toroidal_decomposition
synchro1
@Tom,
Your description of the motor's power is really mind blowing! You realize that you are unleashing a Tsunami high on the Richter scale with your disclosure? A pivotal event in history.
magnetman12003
The single rod magnet inside the plastic tube is very powerful when directed downwards into the 45 degree frame work.  I am going to try another idea I had to make the setup speed less.
Instead of using a single rod magnet. I am going to use a string of  9 mm """MAGNETIC """ hematite beads instead. They fit inside the tubes.
I can place them into the tubes one by one until desirable motor speed is desired.
Need to purchase them now.
Magwood
Can I ask where you buy your supplies? I'm buying some 100mm ring magnets to start with.
magnetman12003
I buy a lot of my items from EBay. Stay away from China sellers now as you might have to wait a long time for a shipment to a arrive. Then you have to ask yourself is the shipment coated with the virus?
Look for the 45 degree aluminum angles on EBay.  Same for the 190 mm ring magnet and rod magnets
You can buy the Gorilla epoxy cheaper than buying it locally.  McMaster Carr has the polycarbonate tubes.
