New Russian Selfrunning Permanent Magnet Motor
Started by hartiberlin, April 04, 2020, 05:41:57 PM
hartiberlin
Hi All,have a look at this new Russian Selfrunning magnet motor.
It really seems to work.
I compiled a few videos of the inventor and posted them here:
https://bittube.video/videos/watch/81d3e71c-2097-46b3-8076-07f7d9a7490e
and here are smaller versions, that you can share more easily and can also download more easilyand share them via Whatsapp or Telegram:
https://bittube.video/videos/watch/afb42712-b127-428b-8ecd-b34133195878
https://bittube.video/videos/watch/ef330d37-7be7-4ec1-b17f-7f588729319a
BTW, I am using the new Bittube.Video Platform now mainly which is a real great platform with full decentralisationand Mastodom integration in the Fediverse...
Anyway, here is the info about these motors:
SELFRUNNING MAGNET MOTOR
This is from an Russian Scientist, which got this permanent magnet motor to run on special magnet gates. I just compiled all of his videos into this one .
first are his latest 2 prototypes that are running and then the videos, where he explained it, how he set it up and got the gates propelling the rotor.
This is really genious.
It is from this Youtube Channel:
https://www.youtube.com/channel/UCqGbLCe3noBFYjwKqml2KeA
and the username is:
Юрий Юрин
As I unfortunately don´t speak any Russian language I can only guess, what he is saying...
I hope Youtube will add automatic subtitles to this video, where you can translate it into your own language.
Hope some users can try to replicate this.
Many thanks for your attention and please subscribe to not miss the next video.
Regards, Stefan. ( Admin from overunity.com)
Юрий Юрин
Berto3
I still have my doubt how he overcomes the sticky point. The video is not running long enough to know for shure if this PM motor is really selfrunning. Till now this video's do not convince me. It is not difficult to make a replication of this setup. Next week I give it a go. Time enough with the corona social isolation. And Yes, enough magnets of the same type.
citfta
I have watched that video several times today.  There is something about it that has me puzzled.  Why does the rotor want to turn when the magnets on the rotor are nearly 180 degrees away from the stator magnets?  Something just doesn't look right about that.  I have not had time to try and make a gate like he has to see if it works the way he shows it working.  I have plenty of magnets.  I just need some time to try and put it all together.  When I get it together I will post a video so everyone can see my results.
Carroll
DaKrampus
Yes I had similar thoughts.. because when something is to good to be true, it often is.
I checked some of his other videos in his channel, and i pasted some of the russian comments in google translator..
this is the video:
https://www.youtube.com/watch?v=ySzQY30GQIk
and here are the comments from the second line:
Rafael Henrial wrote:
QuoteHi Yuri, I will post your video at my place! there will be more who understand how to do
beneath in one of the 4 answers you can read...
Ivan Kovalenko wrote:
QuoteI liked the first video deleted by the author, where a hand-shadow with a magnet is visible helping the rotor. Ah, here it is https://yadi.sk/i/VzZS0Wu5m05cCA
I checked out that video.. but there are so many shadows.. i cannot detect the one that ivan guy is talking about....
If I have time i will try to replicate..
Luc
gyulasun
Quote from: DaKrampus on April 05, 2020, 03:30:37 AM
Luc
Hi Luc,
In this video https://yadi.sk/i/VzZS0Wu5m05cCA  when he starts the rotor from video time 1:37, a faint shadow appears and disappears in the lower right corner where I encircled it in red.  The shadow always appears whenever the 3 rotor magnets are passing around the 11 o'clock area and disppears when the 3 magnets are passing around the 1 to 2 o'clock area.
Notice that I indicated a white triangle section with a black rectangle (between the 2nd and 3rd stator magnets, counted from the left) which also changes as if a shadow would periodically cover the white triangle section:  it is made by the 3 rotor magnets when they cover the light beam as they pass at the 12 to 1 o'clock position.  This is normal, no problem with this latter 'shadow casting'. The illumination comes from the top right direction I indicated with the black arrow and the 3 magnets cast their shadow onto the white triangle.
I also encircled in green the two support legs of the platform on the left hand side where he uses spacers (made of folded paper) to make the left hand side of the platform a few mm higher than its right hand side (i.e the platform is tilted a little).  This causes the rotor use a little advantage from gravity, i.e. from the 12 o'clock rotor magnet position to the entry of the stator magnet row (up to 4 o'clock), gravity can give some torque and defeat the entry sticky spot to the gate.  Of course this small torque advantage should be compensated by the kick out force the gate should provide when the 3 rotor magnets leave the gate around the 8 o'clock area.
Gyula
