Nelson Rocha Workbench
Started by hartiberlin, April 30, 2020, 02:57:05 PM
EMJunkie
Quote from: nelsonrochaa on May 29, 2020, 12:27:33 PM
Hi Chris ,
I appreciate your thoughts and I would one statement about what I think.
"Of course, this series of Magnetic Interactions in the proximity of the Conducting Coils, is important, of course Electromagnetic Induction occurs every time The Magnetic Field Changes in Time, or the Current Changes in Time in proximity to the Conductors."
Electric current produces a magnetic field . But  Magnetic fields can also be used to make electric currents ,exist  a connection and mutuality between both .
we call current to the rate of flow of electric charges in a conductor or by example in a coil of wire .the higher the speed this charges can flow, the higher is the current, like the opposite happens when a magnetic field is accelerated, the current will increase too. This makes either the current in space or the magnetic field in time have reciprocity between them .
Our mind normalizes all motion to unit time this way a reduction in time is equivalent to an increase in space.
It is also true, that the variation of an electromotive force, in space and time also generates a displacement current.
So a time-varying electric field also produces a magnetic field and vice versa. Thus, we can see that there is a symmetry between electric and magnetic field.
This is the point that i am most interested in exploring:) :
Displacement currents. That's my main reason for this project with bifilar pancakes coils.
When a pancake coil is exposed to a high electric field, depending on the dielectric materials that make it up, there is a polarization of those  materials, oriented their positive charges in the opposite direction to the negative ones, giving rise to a electric field and this yields an internal electric field inside coil ,Perhaps that is the reason for Tesla underline a voltage gain in these bifilar pancake coils.
The energy gap in the dielectric material's is very large and being the air a dialectic agent, we could theorize the possibility of exist a interaction between positive and negative ionic charges existing in the environment as a way to draw energy from outside to the coils.
Are those charges static?
Tesla mentioned in some of his quotes, about these charges not being static ...
Was he referring to the Displacement currents?
Who will know?
A good theme to explore :)
Best Rewards
Nelson Rocha
Hey Nelson, completely agree, thus we have the Electro and the Magnetic to make Electromagnetic. The observation at 90 Degrees of the one, seeing either the Electro, or the Magnetic, depending on the 90 Degrees we choose.
Floyd Sweet spoke of Displacement Current, I also have Threads covering this topic. It is an interesting topic:
According to Maxwell's theory, the displacement current in vacuum can produce electromotive force on other coil. However, the displacement current in vacuum does not experience electromotive force from other coil. The asymmetrical electromotive forces result in nonconserved energy transmission between any two coils involving one piece of displacement current. In this work, we designed and performed the measurements for such effect. We observed the explicit evidences of non-conserved energy transmission between a toroid solenoid and a parallel plate capacitor. The measured energy increase is well predicted by the numerical estimation.
The Capacitor Plates do not need to be Capacitor Plates, they can be replaced by cleverly thought of Coils! See below image.
I see much resistance to what I am trying to share! It is very hard to trust anyone, but we must soldier on!
Best wishes, stay safe and well,
   Chris Sykes
partzman
Attached below is a pdf of a flat coiled transformer arrangement I developed over several years stopping in 2016 which I termed MEI or Magneto Electric Induction.  The concept utilizes the distributed capacitance between physically close positioned flat coils and the performance speaks for itself.  This device is an extreme reactive-to-real converter and note the peak reactive input power on the Math(red) trace.  I would also point out the current to voltage phase angle as the device is basically a capacitive load, plus the power density for the physical size using the scope probes for comparison.
The input power is based on the 3MHz sine wave as seen on CH1(yel).  To effectively build this type of device for commercial OU use, this sine wave must be synthesized in a manner that would allow the negative energy portions of the waveform to be returned to the power source.  This is done today in any DC to AC inverter that will accommodate a reactive load but the frequencies are much, much lower.
Regards,
Pm
NickZ
Quote from: nelsonrochaa on May 29, 2020, 01:48:22 PM
Hi Nick ,
I will answer you doubts without low details , but the enough for you to understand.
The circuit self-feedback that you talk , have a pre-charged capacitors;
when i use the 9volts battery is only to start the electronic circuit system and to start the circuit control  after that the process of feedback has able to maintain the oscillations , and the circuit control system will start discharge in a "special way " those capacitors , but at same time, happens a process of "recycling" on the load on the output and that portion recyclable  is injected again in the input , ensure the operation of the control circuit, and recharge the capacitors in a loop.
The system can operate for a few minutes or even hours, depending on how it is used and the type of load used (inductive is the best) I designed to use in a motor .
This circuit was designed to have an external input, based on brake regeneration, or even a solar panel on the vehicle's roof to prolong the effect described.
The idea would be to increase the autonomy of an electric vehicle through this process that I described to you. In that time I work on that project the model granted by Daimler, was a Vito E-CELL .
It was a really interesting project but it is not an OU system.
I hope you have clarified it.
Because you are still involved in your project, by Kapanadze Cousin I'll share a bonus :) Make good use of it :)
https://photos.app.goo.gl/J6uVSprTRCjRBaie6
Best rewards
Nelson Rocha
   Nelson:   Thanks for the download, I've saved it for future reference, as it is pretty long but interesting.   You know, after hearing your reply about how the feed back circuit works on that device. I thought, that it works basically the same as what I have. In the sense of feeding some of the output back to the input. Yet, I can not run mine for "hours", or even seconds before it kicks off. Yet, there is feed back power going back to the device's input, but, it is not enough to self sustain itself, as yet. However,   if I were to connect the output feed back loop of my device to two 12v batteries, @ 24v, that are also connected to the input, my device, also would self sustain. Similar to your system.  Until the batteries drained, like happens with your caps. Right?  So, what are we gaining, if fact?  Still no OU nor self running.
   Thanks for providing me with this info,  I do appreciate it. And I believe I understand it all, a little better, now.
   So, where do we go from here???
              NickZ
Raycathode
Quote from: NickZ on May 29, 2020, 09:32:28 PM
              NickZ
No ? Yes it looks confusingly interesting your a great asset Nelson. Raymondo
Bom dia,Senhor Rocha !
Uma decada antes eu lido sobre este inventor brasileiro Antonio Henrique de Macedo Lavigne no "1000inventions.org"
https://web.archive.org/web/20090926071315/http://1000inventions.org/
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=bra&AP=&PR=&PD=&PA=lavigne&IN=&CPC=&IC=&Submit=Search
no 1000inventions era esposto o artigo/of(f)erta sobre este desenvolvimento
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=21&ND=3&adjacent=true&locale=en_EP&FT=D&date=20011113&CC=BR&NR=0001305A&KC=A
poupe se em material/numero de motores em uso na cuisina  e com uma bobinagem capacitiva tambem em energia
Talvez (so) uma visao
Adeus
OCWL
p.s.:
aquando o estadio em Aveiro durante 95% do anno esta vazio e o Euro-Parque em Santa Maria da Feira mais ou menos em igual situacao isto nao da espaco para eventos de innovacao e desenvolvimento inter-/national,um slogan doa annos 70` :(De)S-Portugal e dos annos 90´ : Portugal-radical !
Ou sem "debitos eco-logicos/nomicos" implementar um
" parque 24/365 aberto de in-vencoes/novacoes", in situ= real
e  no cyberspace= virtual ,
4d-lab factory ,free download-shareware-archiv :
digitizer photo to digits,C.N.C,C.A.D.,C.I.M./C.A.M.1 inch = 2,54 cm = 25,4 mm = 2540 pixels a 0,01 mm precisao : cloning/reproduction minimum limit
Comecar com os a(c)tuais  300 millions do PALOP ,ligacao internet,intercommunicacao barata e depressa
agua potavel ,arrefecimento de alimentacao/bebidas/medicamentos ,
Frio para armazenar( 3d foam dome- armazem printer )  alimentos saisonais  :
os agricultores podem ganhar mais / nao pressao de venda por qualquer preco
cada um  pode dar (ideias,material novo/usado) e cada um pode levar( plano 3d/schemata,pecas)
incluido escola/universidades/empresas/organos estatais -interligacao ! Inter-/nat-/ nac-ional
Recolha e transformao de electrodomesticos ? Optimizacao !?
Os journais "Journal de Noticias" e "Publico" tinham as vezes periodicamente artigos sobre innovacoes nacionais !
Eu lembre-me sobre um filtro para agua  em argila/barro da Universidade de Aveiro barato e efe(c)tivo,
sobre o sistema da construcao dum Engenheiro Santos chamado "interbloco"(medalha d´ouro da Organizacao Mundial e umas medalhas aureas mais de outras organizacoes ) produzido por a empresa Nefil em Mangualde : 100 sqm em 5 dias construido,2400 blocos a 125 Esc. cada !
Tenho ainds a pagina do magazin sobre o sistema  "interbloco" e tambem -por pedido- o catalogue dessa empresa !Construir casa em condicao economica como a WASP,Italia : em blocos ou 3d ! Barato e seguro !
Da empresa CAPA em Valongo/Distri(c)to Porto :A prototipagem ,depois do estudo,  da " casa modular" futura similar os objectos archive.orgwww.fabprefab.com
e do Ikea-challenge os "Polikatoikea"-ganhadores
2006/2007 com o Engenheiro Tiago Coelho eu tinha um encontro, nao muito longe da cidade Aveiro,nos arredores com um inventor portugues ,sobre dele era um artigo esposto num journal national , o objecto era : rebobinar motores com "capacitores" ! ;)
O povo portugues nao e stupido ,mas muitas vezes o clima suave e a nao necessidade de trabalhar deixe o pessoal ser visto por outros como " pobre" ! ::)
O pais Portugal tem um contrato com a M.I.T. e por a camera luso-alema o norte e patrocinado por o " Freistaat Bayern/Baviera": aquando tal ajuda( compensacao ? ::) Levar os melhores studentes !?) esta em of(f)erta nao vale uma/duas/... penas a recusar innovacoes internacionais,talvez - por gratia- porque os inventores sao so desenvolver uma ideia velha e ja esposta oficial  ( nos archivos  ) e sem direitos e limtes com(m) erciais !
Aeroporto Beja : com 3000 Euros e mais custos/gastos  por mes de "Seniorenresidenzen/old peoples home/lar 3ra idade" na Europa-Central o Alentejo pode se transformar num "cocooning place" para os reformistas/pensionistas do norte !
A Costa Vi(n)centina est larga ! ;)
" Aldeias verdes " sob ideia Dante Bini ,integrado na paisagem,podem ser uma solucao win-win !
Nos Estados Unidos ha zonas aonde so pessoas de alta idade podem viver ,interdito jovens : zona Phoenix,Palm Springs  ,condominios fechados !
Multigeneration aldeias dao mais ganho a todos : dar e levar !Ao lado de communidades rurais ? "Leben /Urlaub auf dem Bauernhof/-Land" com todos Mega-City-Services  8) e inter-drones teleferique
Aviaons/planes/Flugzeuge from long cabin to UFO-round,P.M.-magazine 80' exposition,
start area anymore long piste:  Air carrier Hawk : vertical lifting/start ,helicopter like
70' :Radio (Telvisao) Luxemburg " Spiele ohne Grenzen"
2020- "Unvermindert Leben mit geringen Grenzen "
