Thanks to ALL for your help!!
High efficiency or overunity?
Started by GerryC, June 18, 2020, 03:59:20 PM
GerryC
Quote from: gyulasun on June 18, 2020, 04:47:49 PM
Hi Gerald,  the max yet correct size is around 900 - 1000 pixel horizontally, unfortunately.
If you could reduce them to that limit, it would be fine.
Gyula
Fixed to 1000 pixels width.  Thanks!
Floor
Oversize images make it necessary for the reader to side scroll in order to read all subsequent posts.                                        awkward !
Although after (enough ?) time passes the topic's page turns and the problem self remedies, except for upon the original oversize image page.
I think a low resolution JPG format, will automatically shrink the size here (at O.U.).
If you post an image, quick check it, by reading your post immediately (there is a time limit in which you can modify a post within). If the image came out oversize, click modify, clear the attachment,  change the image size as I suggested, or put it into another program (Like draw) and re-size it and try again.
You'll get your technique down.
           floor
