Kundel Torque Amplifier
Started by synchro1, July 15, 2020, 02:50:24 AM
synchro1
two axial polarized disc halves connected to one another for both slider plug and tube spinner piston.
synchro1
the large diameter diametric is not fighting the rotor magnets This design can't deliver any more then equilibrium!
synchro1
Here's the proof for Overunity with a neutralization coil and double semi diametric tube traveler: Running the fixed traveler down a 6" tube would require 1x of turn force to rotate the slider for the reverse course.
A 12" tube would require 2 times the force. Now the electrical neutralization pulse to mask the slider for the 180 degree magnet rotation would be the same for both the 6" and the 12" size tubes!
At some length, the traveling magnet will generate enough stored power to neutralize it's own strength for the rotation it would need to power itself home!
synchro1
We need to "Orbo" the siamese half's. Shaded Pole neutralization. This motor will should run Lenz free!
synchro1
Why not just turn the Piston instead of the rotor, coupled with a neutralization pulse?
https://www.youtube.com/watch?v=WM3roJbzX7U
inverted kundel polarites and switched rotor for piston turn. The track rail needs to turn with piston and reset the spline key in a new groove. This represents a "Quantum Leap" over Kundel's patent!
This would run around continuously in a circle if you neutralize pulsed it through the gate! The neutralization coil could be around the outer tube.
