Magnetic Air Coil Generator MAG
Started by BorisKrabow, July 26, 2020, 01:55:16 PM
BorisKrabow
 Hi !  My humble attempt at creating a solid state device .  :)
            Technology : Exposure to one magnetic pole on the midpoint between the identic poles of magnets .
            Description :  The magnetic field is easier to control outside the ferromagnetic . Air is good for this .
    We have two air coils placed between the magnets . The magnets are facing each other with the same poles .
   A ferromagnetic modulator is located between the air coils . The ferromagnetic modulator is made in the form of a grid.
   The ferromagnetic modulator has a coil that acts with one magnetic pole.
                                        Estimated results  :  a small impulse of the modulator causes large fluctuations in the magnetic field in
the air coils .This leads to the receipt of electricity much more than was expended .
                                        Addition  :  the waveform for the modulator will be found using tests
        Design changes are possible  .
                               P. S.   I use Google translate. There may be distortions during translation. I apologize in advance .
Best regards,
Boris
BorisKrabow
  Hello ,
Device variant with increased reliability . This design allows parts to be added to improve survivability.
                           What is it for  (  a little humor  )
If this generator is installed on an interplanetary space probe  . And there is a long flight
      Earth - Saturn - Pluto - Nibiru ...  ;D   ;D it will take over a hundred years . You can be sure that the little green men  will receive our device in excellent condition .  ;D
Best regards,
Boris
seychelles
Jeg
Very clever Boris thank you a lot for sharing!!!
You trap magnet's flux inside your ferro modulator by demand, affecting this way the flux that pass through your coils at 90 degrees!!! wow
BorisKrabow
Quote from: seychelles on July 29, 2020, 12:28:39 AM
MY VERSION.
Hi seychelles ,
              nice design thanks . I want to share the source of my inspiration .  Patent US3879622A  John W Ecklin  1974 .
Best regards,
Boris
