Place holder for Patrick Kelly Tribute / open source experiment
Started by ramset, July 28, 2020, 09:50:52 AM
ramset
An apparent anomaly which was supported and mentored by Patrick Kelly, will be discussed here [and elsewhere] in the coming weeks.
Did send a note to Stefan to discuss this topic moving forward.
see also memorial page here  https://overunity.com/18545/in-memoriam-patrick-kelly/msg548523/#new
respectfully  Chet K
Thanks Grandma
NRamaswami
I am very grateful for the opportunity to write about the devices Patrick Kelly was personally interested in..
These are the
Hubbard device
Figuera device
Multiple wave oscillator
All are discussed..I have experimented with all.
I have dismantled the Hubbard device and Figuera device and I have a multiple wave oscillator as described in chapter on health intact..the adjustable spark plugs have to be
built.
We are under a lockdown where we are all asked to work from home. I need some time to rebuild the modules for Figuera device and Hubbard device. The modules are basically induction coils.
I will complete each module, state construction details and photos and videos for each one and finally the interconnections
As the entire world is under some type of lockdown I believe that this will also enable every one interested to be able to replicate and test and see if what I state is correct information or not.
90-95% of this effort was funded by me but when due to poor health and financial condition I gave up Patrick and two other friends insisted that I continue. When I recovered I offered to return it but Patrick Kelly and the other two friends refused to accept repayment.
I handled large but low cost and simple to build electromagnets that oscillated at 50 Hz. These are quite dangerous in the sense that we don't realise that they can affect our physiological systems adversely. If you elect to build and test it you would be doing so on your own volition. If you build and test please stand away at least 8-10 feet away from the field. It causes physical inability.
I will be posting from next week. My apologies for the delay.
Ramaswami Natarajan
Jeg
Quote from: NRamaswami on July 29, 2020, 03:29:56 AM
Ramaswami Natarajan
Hi Sir
Thanks a lot for your intentions to share your experience on electromagnets. You have already our full attention after your yesterday's statement about the multifilar primaries and thicker secondaries. It is something new to me as i was born with the notion that primary and secondary have to have the same weight. Looking forward for your tests and experimental devices.
Best Regards
Jeg
NRamaswami
I apologise.
I have no theoretical knowledge. I have not followed any rules for I didn't know them. You just put some body to experiment ask him to observe and learn and improve that's what I did.
I just experimented, failed, observed and improved.. Patrick guided.. because of this there's no notes. No need to worry about anything for I had nothing to worry as I am neither a scientist nor an Engineer nor employed. I am a simple Lawyer trying to experiment and observe. In
No simulation for I didn't know nor do I know as of I now how to do simulation. All observations are based on experimental results.
You will need to experiment and ascertain if what I say is correct. I have stopped doing anything form a few years now due to poor health and finances and had to focus on my health and practice of Law. If you ask any theoretical questions I will not know anything.
This was a tremendous advantage to attempt to learn what works, how and why as I understand them and not based on any books.
I can share the following experiment done many years ago
I shared it with Ramset
Target Greater than 1 COP
Please buy a thick plastic tube 18 inches long 4 inches diameter
Wind 4 sq mm insulated copper wire CCW
You may get about 87 to 89 turns per layer
Wind 12 layers
This is the secondary
Wind a 4 filar coil of 4 sq mm wire on the secondary. Each coil should be 90 to 100 metres long in primary
Put iron rods and hammer them into the plastic tube
If you create an electromagnet for 50 Hz 220 volt input you will draw 15 amps.in primary
The load will be approximately 3000 watts in output but you can load up to 17 incandescent bulbs of 200 watts each. You will probably get 300 volts and 10 amps in secondary
91% efficiency. No theoretical problem here..
How would you increase the efficiency? Test and observe and then let me know. No magnetic amplifier..
Please try to actually build and experiment..This will take your time.
Let me know how you would increase the efficiency. Us ut possible to increase it to greater than 100% efficiency? How?
Simple device..
But I will come back only after Saturday..
Ramaswami Natarajan
ramset
Ramaswami
yes you "just" sent this to me and I am glad you posted here...
thank you
Chet K
Thanks Grandma
