Thanks to ALL for your help!!
Should “energy” be redefined?
Started by sm0ky2, October 17, 2020, 01:35:13 PM
sm0ky2
What do we consider energy to be?
Is it the displacement of an object relative to water under Earth's gravity as standard pressure at 1882's Sea Level?
Is it the current BTU equivalent of our commercialized fuels and energy products?
Is it our relation of the Joule under theoretically ideal conditions?
Is it the work required to accomplish a given task?
We can crush a walnut by hand. And measure some "energy" it took.
We can use a nut-cracker and use less energy.
But how much energy does it take really?
We can hook an engine up to power the nut cracker and decide that
it takes so many BTU's to perform the task.
How about moving a 2-ton object up/down, side/side?
Can we equate that to a BTU?
How many BTU's is required to lift an elevator full of people?
Now consider that same situation, with a counterbalance....
If i have 2x two-ton objects, perfectly balanced.
A child can move them anywhere they want.
Now place the walnut under one while it's moving downwards
And the walnut was pulverized with incalculably small amounts of energy.
ThermoDyscammics was invented to keep your mind enslaved.
Keep you enslaved to the system you work for.
I'm not to make a child's game of the whole of science, but let's put things into perspective here.
Archimedes showed them how to do it in 300something B.C.
We built cathedrals and castles all over the planet with no machinery.
With internal grandfather clocks in every tower powering large grinding mills, and pumping water.
No power bills
No gas in the tank
Knowledge is a tool to divide those who are trained as slaves
And those that truly posses the knowledge.
bistander
Quote from: Cadman on October 13, 2020, 01:03:44 PM
".. electrical energy going through a DC motor.."
He's quoting himself in a reply to me.
I'd sure like to know Cadman's definition of energy. He won't tell me. He thinks it's funny.
Any help is appreciated.
Regards,
bi
For example : Watt equates Joule equates Calori
Monolith Dome Institute :US conventional building construction 112 sqm or 1200 sqft
                     building area heating energy peak : 12000 Watt
Okay,the US has different climate zones,from sunny estates like Californis and Florida to less sunny estates in winter
like Idaho or Michigan : -20 Celsius and below
John Cletus Williams,lived in Georgia, US8059946, heating device inventor wrote some details about effectivity :
400 Watt electric consume for a 185 sqm or 2000 sqft house per hour
Taking MDI numbers 185/112 of conventional building area comparison  we can assume up to 18000 Watt peak heat energy need ,how much electric energy input ?
Can electricity -per se - and device dependent get * heat pump C.O.P. greater 1  * function ?
     1 electric Watt unit input = ? heat Joule/Calori/BTU units output
What does the promotor Allan Hegland maddsci.tripod.com/george
means with the Franco Jakelj electric motor performance :can outperform any existing electric motor now in use or undergoing testing by a factor of at least
                                1000 in terms of torque out  for Watts in , ......
Sincerely
bistander
Even google comes up empty on "Franco Jakelj electric motor".
And:
"For example : Watt equates Joule equates Calori"
Bad example as watt does not = joule.
Watt second = joule.
Regards,
bi
http://maddsci.tripod.com/george/index.html
and W=   J/s     or      J= W/s     or            cal= W/s
but :   P = J/t
Work( in Nm or J  ) is energy/time-unit related  but : W = F * s , F in Newton here s=strecke,distance ergo meter and not s for sec
and now : Raum-Zeit ,Space-Time  question :space unit ?
Can time becoming negative ,by comparison yes !
Can space become negative,beside expansion we have also compression,by comparison yes !
Gewicht,mass ? Before,after ? Wichte,specific mass ? Before,after ?
Gesetz des Dralls,what is physical *Drall* ? Angular momentum
Volume ! Specific volume ?
Hirarchy : power/Leistung  work/Arbeit   energy  force  pressure
Sincerely
