Chinese Oscillator and MOS FET Driver, Hardware experiment
Started by AlienGrey, November 13, 2020, 04:37:08 PM
Jeg
Quote from: synchro1 on December 05, 2020, 07:11:01 AM
Packing the PVC core with magnetite composit would be much simpler then shaping that rectangular job right?
There its really not much to this build; The coils are household wire! What kind of advantage would there be in building a ferrite core with blocks? Permeability can be controlled with particulate ratio.
Yes this is true. Only the total ohmic resistance will change. I used ferrite rings for this task.
What is your opinion on the voltage across the 28T coil? Should it give a voltage level depending on the turns ratio, or it also depends on other factors due to the in series resonance?
synchro1
Quote from: Jeg on December 05, 2020, 07:46:20 AM
That shift in voltage could be caused by incorrect grounding of your oscilloscope. How is the scope grounded?
Jeg
Yes it is grounded but now that you say it i will check again. My Rigol's probes are all grounded.
Ahh do you think it is because we have a zvs driver? The primaries are in a parallel tank circuit which gives rise to voltage. Perhaps that is the reason.
synchro1
Quote from: Jeg on December 05, 2020, 07:55:06 AM
If you are reading voltage off the 28T coil, that coil itself needs to be independently scope grounded to get an actual measurement.
Jeg
Quote from: synchro1 on December 05, 2020, 08:04:40 AM
If you are reading voltage off the 28T coil, that coil needs to be grounded to get an actual measurement.
Yes i have connected one side of it to the negative of the pwr sup and also to the ground through the probe's alligator clip if this is what you mean.
