perpetual magnetic toy and explanation
Started by glaysonmestre, November 22, 2020, 11:18:02 PM
Changing the holding = attraction  PM by an electric energy spending EM ?
"Work " definition by energy spending now satisfying resolved ?
Hybrid EM-PM ,PM with by EMF the total MMF magnifying,neutralyzing,diminuation e-coil unwrapped ?
Learning to treat 'definitions/thesis/formulas' correct use !
And from 2020 p.C. review !
Unwrapping e-coil sourced -instead - by steady electricity delivery : pulsation,pulsative ,repulsative
capacitive,recycleable,fast
winding=capacitor
with Back-EMF-cycle  circuit
Physics + Electro-Chemistry
Lever/Hebel : Physics definition !
Inertia,Physics definition
HUB-/ZUG-Kraft/Force Physics definion and in applying one or the other the input tosame outpt difference
JNaudin : Push&Pull difference
Flynn Parallel Path:  only PM and with EM tests and study
Geminieletricmotor: conventional only 50% from possible MMF transformed,geometry !?
et cet ........
NS and SN
ccw and cw
1x NS PM +1x NS PM  - counter-rotative : lever= amplificator
(PM + EMF-coil )+ ( PM + EMF-e-coil)
Alignment : orbital direction
From coil unwrapping,band foil unwrapping,EMF-layer ink sputting like solar dots in nano powder dimension
Sincerely
skywatcher
I found some ferrite ring magnets (28mm diameter, 10mm hole) and played around with one of them, and some small other magnets.
But i did not find such a 'dead zone'.  Maybe the ring magnet was too small...   :-\
glaysonmestre
Quote from: skywatcher on November 25, 2020, 05:34:46 PM
the dead zone is very small the magnet has to be small, and with a weak local strength his strength using fire
lota
Hello
I have recreated the part. But it doesn't work that way. The problem is the small magnet. Or there are two. It rotates heavily because the forces between the magnets are too great. In one video you can see that the little magnet does not move when it breaks it down. He moves with me.
I write with translator hopefully you can understand that.
Greeting
Lota
lota
Hello
at the blue arrows opposite poles are formed. (reply#12)
Greeting
Lota
