Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
weri812
hi  is
it took my by suprise too
watched at least 10 times   i ask question  emailed the builder.
after about 3 weeks the builder sait that it is a tuned  circut  to the rf out of a cb radio.
wer
PUT YOUR MIND IN GEAR BEFORE  YOU PUT YOUR MOUTH IN MOTION
Bruce_TPU
HERE IS THE ANSWER !!!!
I have urgent news to pass onto you.  This may be the most important post of my life.  After long, long hours of going over every word that Steve Mark has said,
I HAVE FULL UNDERSTANDING of how the unit works!!!!!!!  It finally hit like lightning (no pun intended) this afternoon.  I will use Steve?s own words to explain it Step by Step.  It is so simple, but so complex just as he said.  And once you UNDERSTAND HOW it works, the actual coil design just becomes that of preference.  You will also see why only the ?controller? was patented.  I am not an electronics guy, and maybe that is why I could LISTEN to all that he said and not interject my own thoughts and opinions into the clues.  All I ask in return for this information is two things:
1.)  Your second completed coil with controller sent to me to keep.  (I could not even wire a schematic correctly.)
2.)  Your finished diagram and total information posted here for the world to see.  You can keep the over unity prize money and use my portion to reimburse yourself the expense of my completed unit.
He has given us EVERYTHING we need to understand the how and why his coil works.  Sometimes in obvious language and sometimes in much hidden language, but not so hidden after I point it out to everyone!
Step one:  Remove all thoughts of putting electrical power going INTO the TPU.  It is not a transformer!
Step Two: Build the controller for the unit.  (You WILL KNOW HOW to do this when you have finished reading this!)
Step Three:  Start with a core.  I recommend 1.5 inch diameter plastic tubing (or something similar to dampen vibrations) put into a 5? circle forming the coil shell.
Step Four:  To Make the collector he told us.  ?It is three SEPARATE coils of multi strand copper wire laid ONE ON TOP of the other.?  (remember, he said the frequency changes automatically(PROPORTIONAL) based on the ?circumference?  This is why they are laid one on top of the other to slightly offset the frequency running through each one.  We will get to that soon.)  Three is important, they can be hooked in series or parallel.  It give you greater flexability.   I would suggest using #14 g. stranded.  (Lamp Chord) Strip the ends exposing the strands on both ends.
Step Five:   Make the ends into a ?spark gap?.  This should probably be done at the ?top? of the unit.
Step Six:  Place a LARGER wire, (less resistance) BETWEEN your spark gap.  Perhaps #12 or even #10 Stranded.  This is how you get those silly electrons to go where you want! We will call this our collection area.
Step Seven:  That larger stranded wire runs from BETWEEN your spark gap (make sure it is stripped and exposed but not touching.  This becomes your first control wire and is ?wrapped perpendicular of the collection wires.?  I do not think direction of wrap is important. Similar to what you have done.
SPARK GAP:  HIS WORDS:
Clue #1  Spark Gap
?The key to the KICK?S strength and appearance was in how fast Tesla discharged the capacitors into the spark gap AND how fast Tesla STOPPED the flow of current AT the spark gap.?
Clue #2  Spark Gap
?These electrical effects could be made to create electrons on other wires and copper around his STOPPED current/discharge wire.?
Clue #3  Spark Gap
?All these frequencies occasionally MET at the same time with a much larger kick at the output.?
Clue #4  Spark Gap  (From the ?Parable?)
??and was worried that they all might arrive back at his castle together so he DISCONNECTED the return wire before any of them arrived home.?
??twisting and turning round and round when they noticed that their END CONNECTION was somehow gone..?
?it really was a case of either jump or be pushed.?
HOW IT works and what the controller needs to do.  THIS IS THE UNDERSTANDING:  After this we can experiment to our hearts content.
To MAKE the TPU function, a controller must be built that does the following:
1.   Pulses (or straight, not sure which will be more effective) of High frequency (DON?T WORRY, he even told us which ones work!! LOL) The high frequency is pulsed FIRST into one of the 14 gage wires at the ?SPARK GAP? Traveling CLOCKWISE (might be opposite of what I write and be counter clockwise first, and will be easy to experiment and find out.) and THEN (here you have one of two choices, but one of them is the answer.)
CHOICE NUMBER 1:
The second wire is then given a pulse/input traveling in the OPPOSITE direction.  This is what he calls a ?Harmonic? (Counterclockwise if the first collector wire received clockwise.)
The third overlaid collection coils then receives the input the same as the first.
His Words:
?LISTEN, you need to make three coils or so one on TOP of the other.  There needs to be three of them all the way around.  START THEM UP ONE AT A TIME each.
First Frequency then second harmonic component into the second (INPUT in opposite direction) then the third.
Choice Number 2:  (THIS IS the one I would try FIRST.  I think this is IT!!!)
Wires 1 through 3 are fed ONE AT A TIME, HIGH frequency in the ranges he told us and THEN wires 1 through 3 are fed ONE AT A TIME, ?Harmonics?.  THIS IS the same frequency headed in the opposite direction.  WHEN THEY MEET AT THE SPARK GAP you have (BIG KICK)
2.    So now what you have are two separate and distinct, very high frequencies traveling on the SAME STRANDED WIRES in OPPOSITE directions.  This will later give the unit it?s gyro like effect.
Clues:  Same Wire Different Direction Clues in his words:
?The control frequencies are important in order to MAKE POWER from the collector?
?When I began to study the effects of multiple frequencies COMBINED TOGETHER..?
?I found out that when you deliberately strive to create the worst case scenario of frequencies you start to get some very measurable kicks.?
?But if you make enough of them fast sendoff, you get a collectible power spike that is MORE then the power available to begin with.?
?ALL these frequencies OCCASIONALLY MET at the same time with a much larger KICK AT THE OUTPUT?
?The MULTIPLE frequencies TRAVELING AROUND the coils are of too high a frequency to provide for any motive effort?
??it is related that Tesla states that you can have all kinds of electrons flowing through a wire TRAVELING IN DIFFERENT DIRECTIONS relating only to their potential power source.  He even said that you could have DIFFERENT electron flow through a single wire completely separate from each other.  I TRIED IT AND HE IS RIGHT!?
?In the case of my power unit, you create several frequencies WITHIN THE SPACE of the collector coil?s (three separate ones!) CIRCUMFERENCE.?
?Rotation of field?How many people think about that.  If you could have a field that you could think of as a big ball.  And you could rotate it in two directions what would the ramifications be??
From the ?Parable?:
?but was more worried about them COLLIDING with each other in his castle?)
The above IS WHY THERE IS A GYRO EFFECT!
3.   The PERMANENT MAGNET is positioned JUST ABOVE the ?SPARK GAP? to allow the weak magnetic field to turn all of those pesky electrons, into current for our use.  IT IS BRILLIANT and UNBELIEVABLY simple.  His own words tell us why it works.  Remove the magnet and the unit simply stops putting out electrical power, ?winding down? as the last of the electrons exit once the magnet is removed!
4.   35K resonance.  35.705K frequency all the way to 245K HZ (one video he said that it put out high voltage and a little frequency about 5000 hz).  This is the range his own words clued us.  He is very good with words and electrons.  He was wanting to give us details without them sounding like details.  It is no wonder he was frustrated no one was listening.  They heard but didn?t understand.
5.   ?The frequency will change with the circumference of the coil.?  In other words the frequency that works for the 4? may not work as well for a larger unit.
6.   THE KILL SWITCH,  please remember this in the controller.  The kill switch need to cut ALL FREQUENCIES being input into both sides of the 3 collector coils!!
(NOTES:  REMEMBER the collector?s wires are the smallest.  Perhaps you could try one coil first to experiment.  First control wire from the spark gap is larger and wrapped perpendicularly around THE INDIVIDUAL COIL, and the Second control wire is the largest and wraps around all of the colletors.)
?Through God ALL THINGS are possible!?  
Regards,
Bruce
SORRY!!  PLEASE GO TO "This is HOW THE TPU WORKS!!!!" Thread to reply.  Thank you!
giantkiller
@btentzer,
Before anybody gets to you for slamming reasons I would like to thank you for putting together the obvious explanations. Based upon what you have put together I can see that you have been intently reading and paying attention. And I might add very clearly understanding the clues.
Thanks for posting in this thread.
If you can put a bitmap here of lines and circles about how you think the layers would look like that would be great. Something simple and sloppy is ok. If not that is ok too.
Others have claimed this is my thread so let me be the official greeter. I also love comical retortes. I have been known to post a few.
--giantkiller. Welcome, everyone has value.
Bruce_TPU
I have put a downloadable pic in a new thread.
Thank you, and please make all further replys to my post at "      This is HOW THE TPU WORKS!!!! Thread. Per Stefan, thanks!
innovation_station
it seams like a lot of thinking is going on in hear well if everyone is thinking and not reading humm.... i played that game b4 too  but hear is a thought form me to anyone what if ottos test   drawing is only the collector?
i will say no more because i dont have to  i will be reading!!
is
