Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
0 Members and 38 Guests are viewing this topic.
turbo
Quote from: giantkiller on May 02, 2007, 12:18:20 PM
Nice coil Marco! I found the magnet coil vid. Imagine the longitudinal torsion if the upper magnet was not allowed to rise!
Also, would it be possible to point me in the direction of the big graphic you made showing the device connections of the magnetic transmission demo a few months back? I've searched it and cannot locate it. Thanks.
--giantkiller.
hi Giant, i'm not sure which demo you mean, i did many tests..
Turbo
turbo
The electon stress, which is what we are striving for, is not overpowered by a huge magnetic alignment. That electron stress, which produces very high frequencies, emits the radiant energy.
--giantkiller.
hi, if we look at the "normal" propogation of waves it looks alot like when we throw a rock into the water the waves will spead in a circulair fashion radiating from the source.
if we look at the radiant energy wave it is diffrent because it radiates in many straight lines away from the source this looks more like when we throw some baking powder on the floor.
Turbo.
giantkiller
Like this?
--giantkiller.
Mannix
Quote from: turbo on May 02, 2007, 01:40:13 PM
"Most of the more successful units we made had control wiring run or wrapped vertically over the horizontal collector wires.  You can see them in the units in some of the videos under black plastic covering.  They were run perpendicular to the travel of the collector wires.
They were run in multiple segments.  Each segment could be fed a different frequency individually and or from a collector section to help perpetuate the oscillation and control."
Turbo,an all
The attached picture shows the perpindicular wires.reffered to in text..we may have assumed that they were one wire in most cases.....what if they were each segments? this is suported by the fact that the segments in the picture are perpindicular rather  than at an angle as would be the case if it wasa single winding...we know that because we have all wound many and they all have an off set ...unlike the picture. You know, like Otto's test....sorry to keep bringing up Ottos test...that was deemd a failure by well intentioned, tubeless expieminters.
Going a bit further, what if they were tapped into the collector wire at exact points on the curcumference where the circuit potential was found to exist..you may need a light pen to find it..Otto used a light pen.
Have fun
Be nice
and be careful!
Lindsay Mannix
Dansway
waves and nodes on the collector...
~Dan
