Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
giantkiller
A huge amount of 90 degree intersections along the wave pressure axis.
Mannix
Gk,
Now that's a beautiful picture!
It gives me a warm fuzzy feeling!
Lindsay
Rosphere
So, where hast thou found thee?
turbo
turbo
Quote from: Mannix on May 02, 2007, 07:15:43 PM
Quote from: turbo on May 02, 2007, 01:40:13 PM
"Most of the more successful units we made had control wiring run or wrapped vertically over the horizontal collector wires.  You can see them in the units in some of the videos under black plastic covering.  They were run perpendicular to the travel of the collector wires.
They were run in multiple segments.  Each segment could be fed a different frequency individually and or from a collector section to help perpetuate the oscillation and control."
Turbo,an all
The attached picture shows the perpindicular wires.reffered to in text..we may have assumed that they were one wire in most cases.....what if they were each segments? this is suported by the fact that the segments in the picture are perpindicular rather  than at an angle as would be the case if it wasa single winding...we know that because we have all wound many and they all have an off set ...unlike the picture. You know, like Otto's test....sorry to keep bringing up Ottos test...that was deemd a failure by well intentioned, tubeless expieminters.
Going a bit further, what if they were tapped into the collector wire at exact points on the curcumference where the circuit potential was found to exist..you may need a light pen to find it..Otto used a light pen.
Have fun
Be nice
and be careful!
Lindsay Mannix
hi, many turns of fine wire on many small segments are indeed a good possabillaty.
Has anyone ever done any research on what happens when we create a magnetic field and revolve it faster and faster. What changes and at what speed or frequency of the pulsed field do things suddenly change?
when the incredibaly fast moving magnetic field shoots by one small segment with many TURNS and one end is connected to the collector, it will induce a high voltage spike on it which will supercharge the collector in the same way the one wire does coming out of an car ignition coil.
All these frequencies occasionally met at the same time with a much larger kick at the output.
In themselves they are not much.
But if you make enough of them fast sendoff, you get a collectible power spike that is more then the power available to begin with.
You see, one little kick amounts to nothing.
However imagine if you had hundreds of thousands of little kicks combining into one big current kick . .
THERE ARE MANY WIRES PERPENDICULAR TO THE MAIN COLLECTOR. THIS IS A NECESSARY PART OF THE DEVICE.
from Carl,
However, what was not iterated
is that the amount of current generated is not only a
matter of the strength of the magnet, but rather the
SPEED and distance at which that magnet is moved
across that wire.  Thus when we speak of moving the
magnet across a small piece of wire at the speed of a
gunshot, you generate a very sudden, high voltage
spike in that little piece of wire.
if the collector is charged to 800 volt due to the many high voltage spikes from the bobine like segments it will be charged more positive then the environment it is sitting in and charged to which is about 300 volts.
this creates a potentional diffrence in charges.
there is a possibillaty it will just suck in electrons from the environment, this is what i am trying to do with my new coil.
Turbo.
