Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
0 Members and 40 Guests are viewing this topic.
innovation_station
i think there was a quote some where on this thred that said
  get it hot with alot of noise!  also i have been looking at my last atempt at the tpu and i think it is verry close to what we all want!
is
Grumpy
Quote from: turbo on May 09, 2007, 01:28:03 AM
Lightning can be described as a pulse train, much like a square wave, with a frequency of zero, and a duty cycle of zero.
"The key to the kick's strength and appearance was in how fast Tesla discharged the capacitors into the spark gap AND how fast Tesla STOPPED the flow of current AT the spark gap.  Tesla used all types of devices to stop this flow of current, magnets, a flame, counter-rotating engines.  His goals were to get the time in which the discharge is STOPPED to be much quicker.  As Tesla did this he found that the perpendicular radiations, the ones from the wires, caused electrical effects to appear in wires and other copper/metal materials near the STOPPED current/discharge.  These electrical effects could be made to create electrons on other wires and copper around his STOPPED current/discharge wire".
hmm  STOPPED, STOPPED, STOPPED, STOPPED....?
What SM is talking about when he speaks of "a pulse train, much like a square wave, with a frequency of zero, and a duty cycle of zero" is known as a "Dirac Delta Function" and the spike is at the extreme far left of the scale - not the middle.  Supposedly this Delta Function has infinite amplitude and zero duration - hence "inifinte energy".  Absolutely stomping mondo signal dudes - for you RF techie types.
Couple this to the fact that torsion leads voltage and voltage leads current - send a delta function down a wire that is long enough for it the signal to be stopped before it reaches the end - and the copper atoms can't respond fast enough - the energy will seak to balance by coming out of the wire as a torsion field - perpendicular to the wire - and this field's strength is linear to the distance and can not be cancelled or shielded.  So, Radiant Energy is a Torsion Field, it is scalar - one dimension - like pressure or temperature.
So, important variables are the length of the wire and the rate of change of the signal. Take any pulse and double differentiate it - very tight spike - only take a couple of caps and resistors.
Look at the images of SM's ring, see caps?, see the double chokes?
I venture a guess that SM discovered that too many pulses = too much collected juice = smoke and flames.  Also, as Tesla showed, you can capture RE from the universe - tap an Earth grid and see what you get - very strong torsion fields there - crater your house in a millisecond.
"Pulling electrons out of the air" sounds like a device that just collects - like Markovich.  "Creating kicks" and "getting more back" sounds more like inducing and collecting - like Tesla.  Either will work - pick one.
"spark gap" - more than just a radiator of high frequencies and such - but not near as much credit should go to this gap as it recieves.  It is just a means to an end and not the inducer of effects.
What happens to the voltage across a spark gap?  It take a massive nose dive.  This is very important and most do not see the imporatance of this simple fact.
How can the rate that electrons turn to follow the potential be slowed so that the RE can manifest?  (voltage leads current in an inductor and all that) By increasing the resistance of the circuit.  Stop the flow of current and the electrons attempt to change orientations, but they can't change fast enough.  Dave Lowrance explains this very well, by the way.
        -Frank Edwards
shuzammy
@ Grumpy...
re:
QuoteWhat SM is talking about when he speaks of "a pulse train, much like a square wave, with a frequency of zero, and a duty cycle of zero" is known as a "Dirac Delta Function" and the spike is at the extreme far left of the scale - not the middle.
Here is the perfect video to describe your post...
http://video.google.com/videoplay?docid=-721789270445596549
Grumpy
Can't do video Google due to corporate blockade.
Can you post as AVI or something?
One more thing:
To stop a pulse before the end of a wire, you have to have a wire that is long enough.
Based on Tesla's method:
Speed of propagation = 185000 miles/second = 11721600000 inches/second
11721600000 inches/second / 1mhz = 11721.6 inch wavelength / 4 (for quarter wavelength)
= 2930.4 inches / 12 = 244 feet of wire minimum
Another example:
10 nS rise time = .00000001 seconds x 11721600000 inches/second = 1172.16 inches / 12 = 97.68 feet
Based on the rise/fall time of your pulse, you can determine the length of wire that is required.
        -Frank Edwards
nong
@GK,
Could I ask back to GKTC1.
Today, I scope GKTC , input 5v and I got the kick 125v output.
Its good (I put more turn in controller).  What about your GKTC1 test,
if you still remembered?
nong
