Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
giantkiller
As long as you all keep posting relevant info we will do justice for Tesla.
@nong,
I will pull GKTC1 out again and pulse it.
In the attached I only show 3 harmonic bands. But you can bet your house that from bottom to top and top to bottom that the rise and fall exhibits a full range of photonic frequency decelerations spectrally.
--giantkiller. Let's make it happen.
Grumpy
@GK,
How long are your wires?
        -Frank Edwards
turbo
ok so some people claim it is impossible to stop the current before it reaches the end of the wire..
now i have spend quite some time thinking about how we can stop the current flow.
so i have come up with this idea:
we take a wire and we make a tap point on it,
now as the current starts to flow it will pass the tap point and the disconnect switch will be triggerd and imediatly cut off the flow of current....before it reaches the end of the wire.
we can adjust this circuit by simply moving the tap point on the wire.
just my simple thoughts of today.....
Turbo.
giantkiller
Quote from: Grumpy on May 09, 2007, 01:36:36 PM
@GK,
Collectors are 30 feet and the total of 4 controller segments are 30 feet.
My coil previous to that used 23 feet. That length does not match any of the 7.8hz harmonics.
I didn't try pulsing the collectors though.
I have an elephant graveyard of coils and need to go back through it.
--giantkiller. Saddle up your horses, boys. We got a trail to ride.
turbo
pherhaps you can make any wire match to the desired harmonic by making sure the tap point is at the right place..
you can even use a tap point as an end of the wire while it is actually longer..
this will be my next direction of experiments this weekend.
Turbo.
