Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
giantkiller
Some days it's just not worth chewing off the leash.
--giantkiller. :D
Grumpy
IS -
I admit that I do not have a working ring.  I have some curious things and some things I have not tried yet.  Like everyone else, I find myself continually cought up in the "theory" of the device and spend too much time thinking about how it works when I could be at the bench.  I wound my first about 12 years ago and the second about a year ago - test units.  I ha not heard of SM 12 years ago, but crossed fields and the PX were hot topics.   I'm not an EE and the circuits kill me, but I'm an information hound with a wierd sense of intuition that allows me see through the fog.
The XR2206 chip in the 1mhz units that many have purchased can go up to about 10 MHZ - should you desire to go there.
I believe I could get it to work if I could just get off my ass and do it - it's like I'm blocked, just as most are blocked to understanding my ideas.  This is what I mean when I say that no one can tell you, you have to see it.
Our direction is clear:
"rapidly repeated instantaneous electron flow" - that's about as good a way to get RE as any other.  My translation is rapid unidirectional pulses, since I know that electron flow is not instantanious and that the tempic (torsion or scalar) field begets the electric field and th electric field begets the magnetic field.
All FE that I have ever heard of has been tied to the torsion field  - all of it.  Sweet's VTA, Grey, Tesla, Bedini, and every other one.  Time is not fixed and when it varies - you can get extra energy from it or blow yourself straight to hell.
So, in light of getting off my arse, I wound up a 5lb copper paper weight last Sunday.
100 feet of #14 wrapped around a length of 6" sched 40 PVC. Slid it off and wrapped a pair of 50 foot #14 (taped parallel - what a bitch that was) toroidal wraps over this core.  If RE comes out perp to the wire - then I want the collector all around the source to catch it.  I can connect the collectors in series of bifilar.
Later this week, I will sweep it at up to 50mhz with the freq syn.  Saw wave and square - half wave - positive only - ensure a pause between pulses.  If shit ain't happening, I double differentiate to tighten the pulse as tight as a dogs ass sitting on a persimmon.  (Will have a cap between the source and the ring - fire extenguisher on the side. ) If I see even a hint of a ringing effect - I clip the damn thing and force a cut off at zero.  This is all passive filtering and pretty easy to do. I'm keeping it to low voltage signal so do not expect to start running drills and such.
If there is nothing, then I have to rethink.  Might need to apply an oscillating signal to the collector to create a divergence and then the RE will magnify it - hash on DC.
Gradient divergence curl - in that order.
Post a pic later.  Just build it!!!
        -Frank Edwards
giantkiller
Due to one huge group think the following results were arrived at.
The GK4 exhibits its phenominal effects by executing phase cancellation by mixing different frequencies. This stops the pulse before it gets to the end of the wire at an incredible speed.
So take a 3 segment ring and drive each segment with a different frequency. Can you see the massive phase cancellation going on in the middle collector?
Tubes enable a better level of control due to lower drift. The 555s are sloppy. The drift will cause random stoppage i.e dangerous waves.
The external magfield aligns the electrons and then the excitation can regulate the action of the electron for massive re.
Throw a stone into white water and you still see white water. Throw a stone into calm water and check out the waves.
A big Thank You goes out to Otto, Gnosis, JDO300, Rosphere, Cavetronics and myself included. This was a big hitter. It's out of the park.
--giantkiller. Are we there yet?
Dansway
QuoteThrow a stone into white water and you still see white water. Throw a stone into calm water and check out the waves.
GK at his best!
~Dan
Grumpy
Hmm
and I thought it was molecular vibration with crossed fields exhibiting excess energy do to the time dilation effect of the torsion field
have to work on my theory...
Tesla measured zero current at the disruptor...because the divergence never curled...
        -Frank Edwards
